Miles In A Day
Discussion in 'Ask An Owner Operator' started by swayze, May 4, 2015.
  1. swayze
    swayze Bobtail Member
    8
    Assuming everything is to code with hours of service, what is the range of hours that most drivers would run in a day? 400-700? 500-600? What do you guys think?
    Trying to estimate how long it should take a trip if you know the total mileage.
  3. WesternEmpire
    WesternEmpire Medium Load Member
    342
    371
    Oct 12, 2013
    Arcade, NY
    I usually shoot for 600 miles per day hours permitting. Though I've done a little over 700 in a 65 mph truck on elogs. But literally the planet's have to allign to do that.
    670 to 680 in an 11 hour shift in a 65 mph truck on elogs is more than doable.
  4. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Ungoverned, you can easily go from Phoenix to San Antonio in a 24 hour period (~1000 miles), but that would not be typical elsewhere.
    Unless I knew conditions were good, I wouldn't plan more than 500 in a shift (650 in a 24-hour period)
  5. miss elvee
    miss elvee Heavy Load Member
    816
    2,640
    Dec 15, 2012
    Russellville, AR
    Estimating trip time:
    If you have previous logs take the miles driven and divide by number of hours driven. That will give you your average miles per hour.
    If you don't have old logs, take the speed you plan to run at and subtract 3-5 mph depending on how much and how long you stop.
    Take the average miles per hour and divide into your trip miles. Add 30 minutes for your DOT break, 30 more for any planned fueling, and add 30 minutes for Murphy's Law.
    Adjust your time for things like traffic, pulling mountains, etc.
    Then add it all up. That will give you a pretty close estimate.
  6. reefer101
    reefer101 Medium Load Member
    444
    246
    Oct 24, 2014
    my truck is not governed. 680, 700, 725. Escept Left Coast states where its 55, 60mph
  7. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I push myself as hard as I can. I try to get upper 600's to over 700 when I can. Terrain, traffic, weather, load, shippers etc often dont allow that to happen. I beat myself up when I cant get at least 700mi in on a good day. With that said,.. make no mistake,.. I have had times where 500 - 550 was all I made that day.
    I am anal about trip planning. I know where I should be, when I should be there and where I will fuel and then where I should be to find a place to park in time to have a parking space. Time management is 90% of a drivers business.
    As a new driver, It can be difficult to know where and how things will be. With experience you will learn the best routes and short cuts for trucks when things dont go as planned.
    Hurst
  8. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,424
    Dec 10, 2011
    Weed, CA
    Usually a number between 500-600 will be a good average. However. Lots of things impact your planning. Road conditions, weather, GVW, mountains or flat, the fuel budget on this trip, where to take your break, traffic expectations, so on. One of the big things, for me, is my 70hr clock. I like to run on the recap, so 9-91/2 hrs/day is a good average. Also, if you run a straight 8hrs without stopping, some trips you can avoid your Obama break and still get in pretty decent miles/day. Like Miss Elvie, I use my average speed to plan, quite a bit. Average speed depends almost entirely on how many times you stop in a day. Last planning item for me is traffic congestion. You won't make much money or miles sitting in big city traffic congestion. So I'll set out at 01:00, or so, to get thru Houston/Dallas/Chicago/Twin Cities before 06:00, cruise right thru at 65. LA - by 06:00 it's already too late.
  9. Ougigoug
    Ougigoug Heavy Load Member
    971
    824
    Dec 4, 2012
    Planet earth
    650 miles a day is my target and maybe 95% i hit it, but it require planning and discipline.
  10. Tall Mike
    Tall Mike Road Train Member
    7,292
    34,138
    Aug 20, 2014
    New York State
    I log 700 or so, run as many as I can...
    no restrictor plate, paper logs, and no babysitter..
    Big_D409 and BigBluePeter Thank this.
  11. EZ Money
    EZ Money Road Train Member
    I hear ya Driver.....most of my career has been the same way.
    Log 700 but run 850 or better....shhhh!....lol!
    Tall Mike Thanks this.
