Millis Transfer APUs?
Discussion in 'Questions From New Drivers' started by Kellanium, Mar 2, 2014.
  1. Kellanium
    Kellanium Light Load Member
    59
    Feb 23, 2014
    Aurora, IL
    Does Millis equip their trucks with them and if so are they diesel powered or battery?
  3. Mev
    Mev Road Train Member
    3,109
    1,102
    Jul 29, 2009
    When I was there NO ,
    they did did become very pushy with idle times when I was there ,
    no matter how hot it got , they didn't like us idling the trucks .
    Not sure if things have changed
  4. stevenneill
    stevenneill Medium Load Member
    440
    389
    Nov 11, 2013
    Weatherford, Texas 76086
    They do not have APU's but they do have bunk heaters...they want you to keep idle times down as low as possible, and soon paramaters are suppossed to be set that will cut the truck off if it idles longer than...I think 5 minutes, if the temperature is above ten degrees and below 60 degrees (according to a letter recently sent out). My trainer didn't give a #### about thier idle times and he idled the truck if it was below 32 degrees whether they liked it or not. I checked performance once and his idle time was something like 42 percent.
  5. dmgabe
    dmgabe Light Load Member
    102
    45
    Jun 18, 2012
    Centralia, IL
    Idle limit will be 10 minutes between 10 and 70 degrees. Current policy is to keep idle times below 40%. They did have APUs on some trucks in the past, from what I understand, they where high maintenance in addition to adding weight to the chassis. The last of the APUs left with the trade in of the white regional Columbias last year.
    stevenneill and sapamil Thank this.
  6. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    yes.millis pays for all those super singles on the trucks and trailers by forcing reduced idle/COMFORT times.they bottomed out upon losing the budwiper hauls to weiner and swiftty and whomever else that now pulls it.but hey.it is said that they have an excellent training program if one is so inclined to enter trucking via that route-
  7. dmgabe
    102
    45
    Jun 18, 2012
    Centralia, IL
    If you look at the range of temperatures that the idle limit will kick in, you'd notice that it is well within the limits of comfort. When it's cold, the espar will roast you out of this #### thing, and if it's under 70 open a #### window. If there weren't so many drivers that refuse to shut the truck off maybe companies wouldn't need to implement these policies. The super singles costs are covered by improved fuel efficiency compares to duels and a reduction in weight allowing for more freight in the box.
    i also like like how you imply that losing dedicated accounts to mega fleets is a reflection on Milis. Those companies can underbid just about anybody. You should take it as a positive siign that Millis wouldn't bid peanuts for those accounts.
