Millis Trucks
Discussion in 'Millis' started by th3hitman316, Sep 2, 2012.
  1. th3hitman316
    th3hitman316 Bobtail Member
    24
    Aug 14, 2012
    Giant Nation NYC
    Does millis have APU's in there trucks
  3. Truck It
    Truck It Light Load Member
    185
    36
    Jun 19, 2012
    No .... idle policy goals and bunk heaters. Inverters allowed, however they must install and I am hearing the shops are having a hard time to getting around to having enough time to install them right now.
  4. playamwj12
    playamwj12 Heavy Load Member
    810
    930
    Aug 22, 2012
    I've heard the idle policy is 40% what's the truth to this? And what's the easiest way to make sure you don't go over?
  5. Truck It
    185
    36
    Jun 19, 2012
    I believe it's to be under 50%. Best way to hit this is shut down anytime you can. Your idle time get's killed if you run the truck every single night while you sleep. So if you get in the northern states it helps meet the goal if you shut down on cooler nights. Once the weather cools down here meeting that is not even a problem, the bunk heaters in there will broast you right up.
  6. L.B.
    L.B. Third Generation Truck Driver
    2,654
    1,055
    Jul 23, 2007
    Middle GA
    There are a few trucks running around with apus. I think they were testing them. Have not seen any on the newer trucks.
    Btw in the southeast regional, idle time is 50% in the summer, 40% the rest of the year. There is an idle bonus if you are under 20 or 10. Can't remember which. I've only ever got it twice in the last year.
  7. MojoPotatoe
    MojoPotatoe Medium Load Member
    324
    92
    Aug 31, 2011
    Fremont,Indiana
    I am not sure what the percentage is on idle time but I stay comfortable and see the idle bonus on my check every month : )
  8. db2681
    db2681 Heavy Load Member
    843
    624
    Jun 13, 2011
    Dayton,OH
    50% in July,Aug,Dec,Jan.
    Winter time the bunk heaters do a great job of keeping you warm, if its below 20 you need to idle the truck anyways to keep beer from freezing. Maybe be lower than that on temp its in the handbook.
    In summer I bought a 12v fan and it helps, just close your curtains while driving and blast you bunk air, will have it nice and chilly most of the night.
  9. Boomer 1
    Boomer 1 Medium Load Member
    421
    137
    Oct 26, 2011
    Central, NC
    You have to run a certain amount of miles in addition to the percent to qualify for the idle bonus. Can't remember the miles it's in the book.
  10. jameson bearden
    jameson bearden Light Load Member
    53
    May 19, 2011
    Dalton, Ga
    I run the sleeper air for about two hours before i park and sleep all night without running the truck. But if its 100 degrees outside the truck is idling. A good rule of thumb is cut it off every time your foot hits the step even just sliding tandems. It helps save idle time for those times when you do have to idle
  11. Baritone
    Baritone Road Train Member
    1,096
    570
    Aug 9, 2008
    Lexington, Ky
    I have to admit - I Idle when I need to. I cant sleep when I am hot or if it's humid outside. My idle time can run up sometimes esp when I am in the deep south or in TX as I was last week. It's still very very hot there. Normally my idle runs below 45% in the summer. Big key is turning the truck off when you leave it - no what the reason. Turn if off if not sitting it in.
    Idle bonus means less to me than being comfortable. (just saying)
