Min/Max Blood Sugar Results for Physical Card?
Discussion in 'Questions From New Drivers' started by Bulldog1862, Jan 12, 2015.
  1. Bulldog1862
    Bulldog1862 Bobtail Member
    5
    What is the minimum and Max that you can have on your test for Blood sugar. ???
  3. Dryver
    Dryver Road Train Member
    2,818
    2,575
    Nov 30, 2008
    Sioux Falls, SD
    • At least 20/40 correctable vision in each eye as well as both combined. Glasses or contacts are allowed.
    • Needs to be able to distinguish colors found on traffic signals.
    • Forced whisper test to detect adequate hearing.
    • Controlled blood pressure under 140/90. Prescription medication may be used to control blood pressure.
    • Cannot have diabetes that requires insulin injections.
    • Maximum blood sugar level allowed is 200.
    • No use of a schedule I drug (controlled substance), amphetamine, narcotic or habit forming drug.
    • For any exemptions for vision, diabetes, etc. , please bring the exemption to your physical exam.
    Couldn't find a 'min' level.
  4. G.Anthony
    G.Anthony Road Train Member
    4,564
    5,952
    Dec 10, 2014
    1. Blood Sugar Level: The highs and Lows. A normal blood sugar level is less than 100 mg/dL. Patients with type 2 diabetes have a fasting blood sugar level of 126 mg/dL or more. A normal blood sugar level after a meal is less than 140 mg/dL.
      This is from a website, but it is not specific to truck drivers.
  5. CaptainKirk
    CaptainKirk Light Load Member
    91
    20
    Dec 8, 2012
    Virginia
    There is no blood test on the CDL physical. The urine is tested for sugar. It's easier and cheaper than blood tests and is now as reliable at detecting diabetes.
    http://www.nlm.nih.gov/medlineplus/ency/article/003581.htm
    Glucose is not usually found in urine. If it is, further testing is needed.
    Normal glucose range in urine: 0 - 0.8 mmol/l (0 - 15 mg/dL)
  6. RickyDickyDo
    RickyDickyDo Heavy Load Member
    852
    891
    Nov 22, 2010
    Loveland, Colorado
    Are you diabetic? if so, test your blood and if it is under 140, you should be fine, no glucose will show up. after testing blood, do not eat or drink anything till after CDL physical. Empty bladder before testing blood, this is to get rid of built up glucose in your urine. Type 2 Diabetic here.
    gsmith2332 Thanks this.
