Mini fridge stopped working with inverter but other appliances do?
Discussion in 'Questions From New Drivers' started by xzmpt, Jan 24, 2025.
  1. xzmpt
    xzmpt Light Load Member
    91
    82
    Nov 22, 2022
    I have a 1500 watt Tundra inverter in my truck. Just had it installed a couple of weeks ago at a company terminal. The first company truck I had, had a 3000 watt inverter from the previous driver and I had no problems having my mini fridge and hot stove plugged in at the same time. After it went out, I was told the company only installs 1500 watt. So after getting the 1500 watt inverter anytime I cook with the hot stove, I would unplug the mini fridge. Last night, I did the same thing. Unplugged mini fridge then used hot stove. After I got done with the hot stove and unplugged it then plugged the mini fridge, after a couple hours I started hearing a beeping sound coming from the inverter. After turning off the inverter then turning it back on, I plugged the fridge back in and didn’t hear the beep. Next morning, the fridge wasn’t cold at all but my hot skillet and phone charger still draws power. What is this?
  3. tscottme
    tscottme Road Train Member
    It sounds like a blown fuse or circuit breaker in the fridge popped.
  4. Thrasher28
    Thrasher28 Road Train Member
    1,243
    3,527
    Aug 12, 2021
    Bowling Green, KY
    I’m not sure if it would have caused the mini fridge issue, but the beep could’ve been a voltage warning if you’re in very cold weather. Even with my APU running, running my air fryer when it was in the negatives caused the truck to go into load shed and the inverter to beep for a few seconds while it was on. A fridge doesn’t draw that much power at all compared to an air fryer, but just an idea. The stove might’ve been enough to cause a voltage warning though
    Maybe something like that could’ve caused a blown fuse or something?
    I’m no electrician lol
  5. tscottme
    The fuse for the fridge might be a round cap on the outside back of the fridge where the power cord goes into the fridge. If you know the make and model of the fridge I would google for the PDF version of the manual and read through it about a fuse.
    77fib77, Harry Flashman and xzmpt Thank this.
  6. xzmpt
    91
    82
    Nov 22, 2022
    What are my options? I have a HiSense 1.6 cu ft single door mini fridge from Walmart.
  7. tscottme
    Have you looked for a fuse? Replace the fuse and your fridge starts working again.
    xzmpt Thanks this.
  8. tscottme
    I would turn off your inverter and look to see if the GFI popped. Plug the fridge into a different power outlet you know is working, like in a shop or company terminal, etc. That will tell you if the problem is your fridge or your outlet connected to the inverter.
    Just staring at the fridge and doing nothing is not going to make it work.
    xzmpt and Thrasher28 Thank this.
  9. Arctic_fox
    4,356
    23,489
    Sep 16, 2016
    Ive had this happen. Had some older batterys and when it got cold enough even my laptop could cause issues with power. It actully ended up popping several fuses when it got to -40. Batterys dont like cold and can do weird things when its like -20 or below especially if worn.
  10. Hammer166
    7,561
    27,547
    Aug 18, 2007
    ~8600+' and loving it!
    Have you tried the fridge with the truck running? The startup draw on them is crazy, and if the truck's off the fridge can kick the inverter into overload.
    Thrasher28 Thanks this.
  11. Ridgeline
    22,618
    120,266
    Guys, the tundra inverter is a modified sine wave inverter and it is dirty.
    get a pure sine wave inverter.
