Minimum landing gear clearance?
Discussion in 'Questions From New Drivers' started by double yellow, Jul 14, 2012.
  1. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Is there a certain distance the landing gear feet must be from the pavement when retracted? I cant seem to find anything in the little green book...
    thanks!
  3. flyingmusician
    flyingmusician Road Train Member
    4,288
    10,905
    Feb 25, 2011
    Jamestown, NC
    all the way up until they hit the stops......that's the only good policy in my opinion
    JReding, uncleal13, Gizmo_Man and 4 others Thank this.
  4. FLATBED
    FLATBED Road Train Member
    All the way up Its good EXERCISE :) and no chance of hitting something you did not plan on and damaging it.
    JReding and LaBubba Thank this.
  5. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    My current trailer's landing gear stops about half-way up (8" ground clearance -- and judging from the rust line, it has been like this for some time). But having spent time in the shop with my last 4 trailers & with an inconsiderate shipper already ticking away at my 14, I'm wondering if I can let good policy slide this time ( or if it is instead a legal requirement.)
  6. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    Sounds like it has been that way a while. Does it hang down lower than your brake chambers ? Are their any points on the vehicle lower than the landing gear ? If pads are not closer to the ground than other parts, I would get to trucking, but REMEMBER when you get to a RR crossing, bumps, and stay out of holes that would cause your drive axles to dip down. Just my thoughts, not sure of any legal problem.
    airforcetoo Thanks this.
  7. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    It hangs lower than everything else. The brake chambers are about 12" off the ground -- the differential is about 10". I know the route and am not worried about scraping anywhere -- I'm just concerned about encountering an eager DOT officer along the way.
  8. striker
    striker Road Train Member
    6,026
    6,439
    Aug 8, 2009
    Denver, Co
    not likely they will say anything, I've had container chassis where the landing gear was barely 4" off the ground.
  9. jbatmick
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    Getting close to dark, and this is the week end:cya:. Know what I mean:wave: ?
    double yellow Thanks this.
  10. striker
    6,026
    6,439
    Aug 8, 2009
    Denver, Co
    the freaks come out?
  11. jbatmick
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    Nope, the DOT:smt079:druid: goes in:wink:.
