Minimum Weight to scale.
Discussion in 'Questions From New Drivers' started by Woodys, May 10, 2013.
  1. Woodys
    Woodys Heavy Load Member
    774
    1,629
    Mar 16, 2010
    Tampa, FL
    Ok, this should be a pretty simple question. But will def help me out and maybe some other new drivers. What is the minimum weight you take to a CAT scale. I've still fresh and have been scaling every load over 35k just in case. But was curious where you all draw the line?
    passport220 and TruckDuo Thank this.
  3. samurai
    samurai Heavy Load Member
    969
    212
    Feb 25, 2012
    Fairborn, OH
    why on earth would you ever need to know this? i havent scaled anything under 46000 in at least 5 months.
  4. PowderBlue
    PowderBlue Light Load Member
    236
    94
    Dec 18, 2012
    Clarksville TN
    If your truck is equiped with a air bag pressure gauge it will make it alot easier. I got my drives to 34000 then marked the spot mentally on where my air gauge is. For my truck that is about 69-70 psi. Now I normally slide my tandems till im around 68-69 psi... If I cant get it there.. I know I need to scale it. If im over 45000 I scale it also to check for gross ect. 35k is very overkill if you have a air bag pressure guage. Also dont forget the weight of fuel when adjusting your tandems.. that can add a few pounds to the drives
  5. PackRatTDI
    PackRatTDI Licensed to Ill
    14,765
    22,567
    Jul 15, 2006
    El Chuco, Tejas
    35k is a good limit. My truck has a pressure reading for the suspension and 53psi while driving is roughly 33-34k on the drives so regardless of the weight I slide the tandems on the trailer to achieve that pressure or close to it. Iif its more than 37k I'll double check and I'm usually right on the mark. Unless you're going to a short kingpin to rear axle state like California, Florida or Michigan, setting your tandems to the 41' mark to thecenter of the tandems (legal for Tennessee, Virginia, also satisfies the 43' limit for northeastern states) will allow you to legally scale most loads that are even weight per pallet and arent loaded past the 48' mark.
  6. bigdad7
    bigdad7 Road Train Member
    1,837
    1,364
    Jun 6, 2010
    ks
    Hmmm.......didnt think fl was a short kingpin state will hv to.double check that
  7. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    not until I am at or above 45K.
  8. bigdad7
    1,837
    1,364
    Jun 6, 2010
    ks
    K..but in fl you can run 44k on tandems so i guess ill suck it up a tab b4 leaving ga
  9. Bayle
    Bayle Road Train Member
    3,060
    1,228
    Aug 30, 2007
    Cottage Grove, MN
    They are, but allow 44k on tandems, so in FL if not over gross then no problem.
    edit, got beat...:biggrin_25514:
  10. Steve D
    Steve D Light Load Member
    156
    184
    Dec 14, 2012
    I 39k on a couple of weeks ago, so thought no sweat. Well, rolling across the scales in VA is was shocked to find I was 2400 over on my drives. (This truck does NOT have an air bag pressure gauge or I would have known it.) Fortunately, VA lets you adjust them and try again. Since most of my loads originate in VA and VA weigh stations are almost always open, I just let them let me know if I am over and adjust accordingly.
  11. Numb
    Numb Crusty Curmudgeon
    4,047
    9,270
    Jan 30, 2012
    Charlotte, N.Carolina
    between 25K and 30K, depends on how it looks in the trailer and on the air gauge.
    some loads vary in the pallet weights. could have more in nose or tail.
    bigkev1115 Thanks this.
