Mirror Heat - stay on?
Discussion in 'Freightliner Forum' started by tscottme, May 30, 2018.
  1. tscottme
    tscottme Road Train Member
    I'm in a 2018/2019 Freightliner Cascadia. I cannot get mirror heat to stay activated more than 30 minutes. I've tried a quick press of the rocker switch, long press (30 seconds+). After 30 minutes mirror heat turns off. Is there a way to keep it on? Yesterday I drove all day in rain and had to resort to using timer on phone to remind me to re-activate the heat so my mirrors could stay clear.
    My Volvos had a short press which activated the heat for a brief period. And a long press which activated the heat until you turned off the key or started th engine.
    Thanks for your help.
  3. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,135
    Mar 5, 2016
    White County, Arkansas
    I went ahead and did some light reading.
    The relevant paragraph considering exactly your 30 minute heated mirror complaint is shown in this PDF of the actual Manual for your vehicle. (Or generally your make of vehicle over a range of some years) Your vehicle is behaving perfectly turning off the heating element after 30 minutes.
    Now what I am posting after this sentence is a direct quote from one of two paragraphs in the manual regarding your 30 minute time limit and how to go about getting it changed. The link that follows is the actual Manual that this information came from followed by a chapter, verse and page you need to visit within this manual for further information.
    Now I have always said I learn something new every day and this manual has provided me with a update on what a big truck does these days in pretty good detail compared to say a 2001 Century or a newer 2002 T2000 KW Tractor from back in my day. Without further ado...
    Begin quote
    In order for the heated mirrors to operate, the key
    must be turned to ON. The heated mirror will remain
    on for 30 minutes, as a default setting. The settings
    can be changed by an authorized Freightliner service
    technician. After the defined length of time the
    heated mirrors will disengage only if the outside air
    temperature is greater than 60°F (16°C) as a default
    setting. Outside air temperature is monitored by a
    sensor
    End quote
    Source Link (*You will need Adobe PDF Reader (Free download)
    http://www.transchicago.com/assets/1/6/Cascadia_Drivers_Manual.pdf
    My job for this morning is finished. You had a specific question, and it's answered by this manual linked to this thread.
    tscottme Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    My 2016 shuts off after 30 mins, but if the wipers are going, it will stay on. Also if it’s really cold out it will stay on.
    x1Heavy and tscottme Thank this.
  5. Trucking in Tennessee
    Trucking in Tennessee Road Train Member
    3,740
    5,740
    Mar 19, 2018
    Nashville
    <Going into shock>
    x1Heavy Thanks this.
  6. tscottme
    You rock. Thanks
