Mirror mounts
Discussion in 'Peterbilt Forum' started by Pup97, Nov 22, 2017.
  1. Pup97
    Pup97 Light Load Member
    191
    263
    May 30, 2016
    I am looking for the part numbers for the cab mounted mirror brackets the one that is on the cab. Like to update my truck a little. Any help, thanks
  3. NightWind
    NightWind Road Train Member
    2,663
    18,776
    Nov 11, 2006
    Sunny South, AL
    take the VIN number to your dealer and ask them for the part numbers.
  4. Pup97
    191
    263
    May 30, 2016
    Anyone have a vin of a truck with cab mounted mirrors? I have door mounted mirrors so my vin won't work.
  5. Loaderlou
    Loaderlou Medium Load Member
    342
    131
    Feb 24, 2014
    I looked into that a couple of years ago. My Pete dealer said no issues with the swap. He quoted me about $1200 for both sides, a days worth of work with dismount and mount and feeding all the wires and cables through. The only thing I can see you may want to change would be the air cleaner hat to a shorter one. Otherwise have an extra set of hands for help and a handful of stainless huck bolts to fill in all the old mirror holes. Best of luck.
  6. Luwi67
    Luwi67 Heavy Load Member
    746
    484
    Oct 24, 2012
    Long island
    Don't forget to add the cost of the piantwork involved where the old brackets were.
    Try 7N734207, I pretty sure that truck had cab mount.
  7. Pup97
    191
    263
    May 30, 2016
    I could put chop tops and upper door stainless to cover holes from old mounts? Thanks I'll try that vin
  8. Peterbiltt
    Peterbiltt Light Load Member
    236
    87
    Aug 21, 2014
    Ontario Canada
    i think you should go to a truck junkyard and find a pair. would be much cheaper.
  9. Luwi67
    746
    484
    Oct 24, 2012
    Long island
    Got another VIN for you. This one is an 05 379 daycab with cab mounted mirrors.= N857370
  10. Pup97
    191
    263
    May 30, 2016
    Thanks for your help! 1400 minus the mirrors.
