Missed matched tires, Hi Pro next to a Low Pro on trailer?
Discussion in 'Ask An Owner Operator' started by albloomfield, Jan 7, 2019.
  1. albloomfield
    albloomfield Bobtail Member
    21
    20
    Oct 12, 2018
    After this ordeal I guarantee I'll check, but also isn't there a certain expectation when you hire someone you expect them to know what they are doing? If I hire an electrician to wire my house, my house catches on fire, It's partly my fault if I don't double check his work?
    Timeline, bought tire at Petro 12-28-18 That's when the 11r22.5 was put on. The paper work shows they put on a 275, but they put on an 11r22.5. I didn't realize it was an 11r22.5 until Loves tore it apart.
    Outside tire blows 1-4-19, I drove about 1,200 miles.
    I put a brand new tire on 1-4-19.
    On 1-7-19, I notice there is very little tread, at that point is when I realize they probably put an unmatched tire next to.
    I go to loves, take it apart, and put 2 new tires on.
    I agree, I'm going to make #### sure from now on, but I really don't see how this is on me. I could of caught it sooner, I agree that's on me. But there should be an expectation when you hire someone to do a job, they know what they are doing. I don't think it's too difficult to look what tire is already on the trailer. Then put the same tire back on.
    Samarquis Thanks this.
  3. Samarquis
    Samarquis Light Load Member
    227
    549
    Dec 20, 2017
    Maine
    I understand what you mean. I didn't mean to come across as rude. But your analogy is a bit off
    An electrician requires training and legal licensing before he can work on a customer's home
    Mechanics and tire guys do not. So honestly a trip to McDonald's is a better comparison. Do you check the bag before you leave McDonald's with your food?
    I agree that There should in fact be an expectation that you are getting what you pay for. My view is slightly tainted, as I spent several years as a light duty technician and service advisor... And got to repeatedly break the news to customer's they had been ripped off by other shops. So I don't trust anybody's repair without at least a cursory review of it .
    I hope you get them to cover the cost of both tires. They screwed you and you deserve, at the very least, a refund. Something.
    Good luck with it. Honestly
    Badmon Thanks this.
  4. Long FLD
    Long FLD Road Train Member
    11,812
    48,371
    Mar 4, 2015
    A size difference of that much would be easily visible while walking around the truck. Regardless if it was an inside tire. Regardless if you could see the sidewall or not. You can’t trust the “techs” much these days. This is on you for just jumping in the truck and driving off.
  5. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    No. Unsafe mismatch
  6. adayrider
    adayrider Road Train Member
    1,289
    1,732
    May 7, 2018
    Anytime I've had to buy a tire on the road at a truckstop I personally walk out to the tire rack with the guy and select and inspect as well as price the tire to be installed. No caps, no dry rot, no large patches or boots and personally know that it is correct size and meets my approval. If they don't have a good used tire that meets my approval I will buy 1 brand new tire. Anymore I skip the used tires and go straight to brand new to get me home and when I get home I buy another new one or 3 at a better than truckstop price so not to run unmatched tires.
    If you lay on the ground you will be able to see all writing on the inside tire but you might get dirty. I'm willing to get dirty all day long to save hundreds of dollars.
    Do you go to the bank and withdrawal $500 and leave without counting it before you leave?
    baha Thanks this.
  7. 6wheeler
    6wheeler Road Train Member
    2,696
    4,774
    Aug 30, 2009
    I do road service here in Virginia. Truck tires. That was the Tech's fault. Rookie
  8. adayrider
    1,289
    1,732
    May 7, 2018
    Tech's fault the tire got put on you might say but OP fault he paid and left with wrong size tire.
  9. 6wheeler
    2,696
    4,774
    Aug 30, 2009
    Lol. Not when I worked in truck tire shops growing up. Someone would eat that replace around here. Same thing happened often when a flat repair would come back.
  10. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Just to pile on here. You or the tech never thought to look at it when you got the wheel nuts retorqued within a couple hundred miles? ;) it is mandatory in a lot of places and policy at a lot more trucking companies and tire shops. You're right you shouldn't have to double check pros doing whatever job they do out at the end of the day you're the one thats running around fixing the issue now. So to me its worth doing it. Plus you might learn something from them. The tire shop should step up if you show them the pics and recipts etc. Key word being "should" lol
  11. Badmon
    Badmon Heavy Load Member
    806
    1,503
    Oct 6, 2014
    Deep south
    I agree with you OP, tech should have done his job properly. Unfortunately you learned a lesson the hard way. Find solice in the fact that I have learned a minor but important detail in the life of an O/O from your situation. Better off double checking behind those knuckleheads before we cut out from the area
  12. Danny707
    Danny707 Light Load Member
    188
    180
    Mar 26, 2019
    Hey guys I was wondering if there would be an issue if one of my outside drive tires is a 275/80/22.5 and the other 7 drive tires are 295/80/22.5
