Model 378 ac not working
Discussion in 'Peterbilt Forum' started by qrserv, Mar 22, 2014.
  1. qrserv
    qrserv Bobtail Member
    I've got a 1998 Peterbilt model 378 no power to the air conditioning compressor, no power to on off dash switch
    also the blower ducts only blowing to floor
    the pressure in the system was low so I jumped the compressor added 3 cans hoping The low pressure switch was keeping the compressor from coming on
    anyone know of Typical failures with this system?
    also would love to get a wiring schematic thanks
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Pull off ft. cover off heater a/c look for power at 2 wire temp control in box
  4. qrserv
    if you're talking about the hot(red) to cold(blue) knob / switch There's 4 black wires going to the back of it.
    also I'm trying to determine which PDF file is the correct one for this model?
    I'm working for my android & its hard to get to the wiring schematic list as posted above
    but I did find my way to the PDF files list via a search engine
    Thanks
  5. qrserv
    got the system working
    had a bad AC compressor relay at the fuse block
    couple of missing fuses
    several burnt / melted connectors somebody had connected a hot wire plug in connector to the ac compressor so they were bypassing factory power feed
    which is probably How the connectors got melted, relay got overheated etc...
  6. Longhood379
    Longhood379 Medium Load Member
    389
    125
    Nov 30, 2009
    Cremona AB
    Schematics are linked in the first post if they are still available, they' still there, I just checked (you don't have to log in just click on the drop down)
