Moffett trailer tires
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Kyle G., Nov 24, 2021.
  1. Kyle G.
    Kyle G. Road Train Member
    3,766
    19,673
    Jan 23, 2016
    Eastern Iowa
    I pull a 48 ft transcraft flatbed with a Moffett forklift. Its just about 2 years old and i am looking at replacing the tires soon.
    I have 2 newer tires on the front axle that are a little better than the rest (the other 6 are original) so i may leave them on and get 2 used tires to match them for one axle, then get 4 virgins for the other axle.
    which axle should get the virgins? Does it matter? Given that i have 8000 lbs hanging off my bumper all the time, I am assuming the back axle usually carries more weight.
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,419
    6,434
    Aug 26, 2014
    Is the fact the back axle carries more weight based off a scale?
    Kyle G. Thanks this.
  4. Kyle G.
    3,766
    19,673
    Jan 23, 2016
    Eastern Iowa
    No, I guess I don't actually know that for a fact, i am just assuming because it sure seems like it does.
    Maybe I am wrong?
  5. Ruthless
    Ruthless Road Train Member
    8,816
    86,454
    Aug 28, 2010
    The City.
    Is that trailer spring ride?
  6. Kyle G.
    3,766
    19,673
    Jan 23, 2016
    Eastern Iowa
    Nope, air ride
    Ruthless Thanks this.
  7. BoxCarKidd
    4,419
    6,434
    Aug 26, 2014
    Equalizers between springs and air pressure between bags normally keep axle weights fairly close. Where you put which tires probably does not matter much. More of a personnel preference.
    Search spread axle tire scrub and such. There were a lot of good posts on trailer tires at different times.
