Moisture in the oil fill
Discussion in 'Ask An Owner Operator' started by 1957evinrude, Nov 6, 2018.
  1. 1957evinrude
    1957evinrude Bobtail Member
    13
    im looking to buy a 2012 kenworth with a Cummins ISX. I took off the oil fill plug while engine was running and Could see what seems like a bit of fog coming out but no pressure . I noticed a bit of condensation inside the walls of the oil fill tube. Is this normal. My old truck had filled plug on top the engine .
  3. Ridgeline
    20,737
    101,050
    Well pull the oil for an OA and when you dyno the truck, you will get your blowby numbers.
    When was the truck last run?
  4. 1957evinrude
    13
    Yesterday but was run only at a dealer for a few minutes at a time since about 2 months
  5. 1957evinrude
    13
    The oil has been changed and run about three hours since . Woukd the oil analysis still be accurate?
  6. 77fib77
    77fib77 Road Train Member
    8,600
    49,123
    Jul 7, 2010
    St Louis
    I would do analysis on the oil it's cheap. The mist could it possibly be oil mist from the reservoir?
  7. GreenPete359
    GreenPete359 Road Train Member
    2,137
    5,062
    Oct 21, 2017
    Driving my recliner
    Mist could be smoke. Blow by test takes care of that
    Could be condensation in the oil from the truck sitting. It needs to get to operating temp and ran for a while to burn it off.
