more codes
Discussion in 'Volvo Forum' started by Mlaz Bogdanci, Apr 9, 2012.
  1. Mlaz Bogdanci
    Mlaz Bogdanci Light Load Member
    58
    11
    Feb 5, 2012
    Santa Monica , CA
    MID128 PID 27 FMI 5. MID 128 SID 146 FMI 6. MID 144 PSID 230 FMI 5. Please help anyone.07 VNL 780 VED12 Eaton 10 speed fully automatic
  3. JewelsVTL
    JewelsVTL Bobtail Member
    Jul 19, 2012
    Mlaz Bogdanci Thanks this.
  4. cumminskid123
    cumminskid123 Light Load Member
    107
    59
    Jun 21, 2016
    Manitoba, Canada
    MID128 PID 27 FMI 5 - EGR Valve #1 Position Sensor - current below normal or open circuit
    MID 128 SID 146 FMI 6 - EGR Valve #1 motor - current above normal or grounded circuit
    MID 144 PSID 230 FMI 5 - vehicle ecu - Software Fault - current below normal or open circuit
    i would suspect that your wiring to the EGR valve #1 is faulty or the valve itself, as for the 3rd code, i would check the batteries, for any loose or corroded connections (loose as in the connector on the cable, and the nut on the post... load test the batteries. start simple...
    Rob100100 Thanks this.
