Ok, so I used a butter knife to pop wood gain trim off off dash. All one piece so br gentle. Then I removed the Phillip's screws holding the nav screen/ gauge panel in and pulled it out giving access to the back side of gauges. I removed daisy chain plugs from the back of my def gauge and rear axle temp gauge. Those are the top two far right gauges I am wanting to remove and rearrange. Now it appears that there is a plastic collar that is threaded to back side of gauges that hold them in. Problem is, when I turn the collar the gauge turns in the dash. So does anyone know of a tool or procedure for removing the gauge. Called dealer-no help.....
More help with 06 and newer dash/gauges
Discussion in 'Kenworth Forum' started by w9l, May 19, 2021.
