I have a 2010 pete.isx 15, 600hp cummins 2050 torque. I haul wood in northern maine and the dealer says shes all they will crank it to. Hauling 100,000 to 130,000lbs id like more power. I have the heavy clutch and trans with 46,000lb full locking rears. Any suggestions for low budget power that packs a punch?
More power
Discussion in 'Peterbilt Forum' started by bringthenoise, Nov 18, 2013.
5 hours after i posted this i lost the front rear input bearing. I have only put 30,000 miles on it. It has 255,000 on the truck. Is that a sign of previous owner abuse or do heavy loads lower there life span that bad?
For the power question post a thread in 18 wheelers pinging Mr Haney, he's your guy for more horses.
bringthenoise Thanks this. -
man, i did just fine with 475 horses pulling 100k. in the western mountains.
i wished i had 600 and wanted more. -
Yeah i have a 98 pete im driving right now. Ol reliable. 475 e model cat. Im just trying to make a force to be reckoned with. Power is reputation here. These guys get serious. Being 25yrs old im trying to build my rep as a powerhouse
Hope your bringing your wallet to the table too. There's more to big power than a 800hp engine. Everything behind it has to be able to hold up.
Richter Thanks this. -
In summery:
Get FASS
Get Fleet Air Filters if they have one for your truck
Call a 3rd party tuner like mr hanky or pitts power -
I have the right stuff behind the power. Questions answered thank. No more input needed
try a V-8 cat or kta 600 cummins, 600 hp is the low spec. on the kta my 79 pete with a V-8 could not out pull the kta engines but thats the way life goes. if you are going to run big power would start with the cooling system you will need electric fans to keep the engine cool on the pulls, an 18 speed might be ok but a heavy duty 10 over or a set of brownings 5X4 will work good . and the drive train will need to b beefed up a little. my V-8 averaged about 4 mpg pulling a meat trl to the west coast, the kta 3 1/2-4 would b about rite. lots of luck
