More Volvo nightmares. Code: MID130 SID251 FMI5
Discussion in 'Volvo Forum' started by silver dollar, May 9, 2018.
  1. silver dollar
    silver dollar Medium Load Member
    481
    211
    Jan 31, 2009
    Central North Carolina
    Greetings, I'm here again with more electrical problems. The truck is a 2004 VNL 630, D12D 465 with Eaton RTO1691C-AS2 auto-shift transmission. Occasionally the trans will miss a shift, then find it. When I check the diagnostics, there's an inactive code MID130 SID251 FMI5. As best I can decipher, the code is for transmission ECU power supply. Yesterday morning the code was an active fault and the truck would'nt start. When I finally did get it started, it would not shift right. later in the day it was ok. I think I'm intermittently losing power to the TECU. I have 3 power leads coming from the batteries. I think one is the engine ECU, one is trans ECU, and I'm not sure what the third would be. I guess my question is; can I buy the TECU power supply harness or just try to find and fix whats wrong? Any help would be greatly appreciated. Thanks
  3. Aces-N-Eights
    Aces-N-Eights Light Load Member
    135
    200
    Feb 21, 2018
    Mobile, AL
    I'm probably not the right person to give advice on this... however I do know from experience that AT trans are FINICKY about power. Had a buddy with an early 2000s Volvo who had probs with AT. Swapped battery cables and cleaned terminals and the problem cleared up. Of course he did this after 2 trips to the mechanic that cost him thousands.... smh. Just a thought, hope it helps!!
    Bean Jr. and silver dollar Thank this.
  4. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    If you are willing to get a bit dirty, it's not that bad to follow power/ground leads from battery box area back to tecu. You will need a good, sharp cutters for zip ties and a good light. Come on, it's spring time.......you can do this.
    silver dollar and Socal Xpress Thank this.
  5. silver dollar
    481
    211
    Jan 31, 2009
    I think I can, I think I can, hehe. I was under there today. I saw which power lead was to the engine and trans ECU's. The third lead is to the Wabasto bunk heater. Although I didn't find any problem as far as I could see, I did remove and clean all the cable ends. I will next take the batteries out to see if it will give me more access to trace it all the way to the TCU. Thanks for the reply.
  6. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    you can buy the whole harness which comes with power supply and more importantly it comes with data and ign wiring as well, usually after some time they just start going i think the harness is around 250 put it in one time secure it good make sure it doesn't rub anywhere and you should be good for a long while, i've tried fixing them and they work just fine until the next wire breaks and it just gets to be a #####.
    silver dollar Thanks this.
  7. silver dollar
    481
    211
    Jan 31, 2009
    Thanks @nasriza How much trouble is it to replace the harness? There appears to be an access panel in the floor. Any special procedures to doing this job? Thanks for you help and the reply.
  8. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Not that much Pretty Simple just follow connections
  9. QUALITYTRUCK
    1,816
    1,782
    Jun 14, 2009
    romulus,mi
    I wasn't going to tell you about the floor access panel because it might require some floor covering being cut. If you open that access panel you you can easily replace the whole harness like Nasriza said. I believe it is even cheaper than $200.
  10. silver dollar
    481
    211
    Jan 31, 2009
    Thanks. I kinda thought that the floor covering would have to be removed or the seats taken out to access the panel. There is a local shop here that has done them before, so I decided to let him do it. I'm just no good in tight spaces anymore. He said 2-3 hours labor. No one close by stock the harness. So Transource in Raleigh ordered one.. $450 includes overnight shipping.
  11. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    u can do it from the bottom just a lot of tight spaces just make sure they secure it correclty
