Most miles you got out of steer tires
Discussion in 'Ask An Owner Operator' started by Coronado2020, Apr 18, 2023.
  1. Coronado2020
    Coronado2020 Light Load Member
    50
    139
    Jul 7, 2020
    AZ
    I replaced my Michelin steers today and got 267,000 miles out of them with 7/32 still left on them. What do you all get out of your steer tires?
    I run a dry van with avg 35k-45k lbs loads all 48. A7739A5F-8492-42B1-9137-041A98FB6B04.jpeg 5FBD0F29-36D2-428E-B7D2-F6483F3E919E.jpeg 4965FC8F-AABA-45AD-A8D7-AA8739D6633D.jpeg
    Siinman, Oxbow, Mattflat362 and 5 others Thank this.
  3. bzinger
    bzinger Road Train Member
    16,611
    65,898
    Dec 10, 2014
    omaha , ne
    I'd suggest you send those to the Smithsonian!
  4. KrumpledTed
    KrumpledTed Medium Load Member
    485
    1,463
    May 6, 2022
    Well balanced and maintained Michelin steers I have seen go 300k before the owner got nervous about them. Looks like you were doing just fine with them. How often did you rotate/balance them or did you use Centramatics?
  5. Coronado2020
    50
    139
    Jul 7, 2020
    AZ
    Rotated every 6 months. New shocks every 9-12months with fresh alignment. Tire pressure check every other morning.
  6. Big Road Skateboard
    6,039
    32,672
    May 2, 2021
    Spin balance, bead balance, wheel end spin balance, centramatics?
    Rideandrepair, Oxbow and D.Tibbitt Thank this.
  7. Coronado2020
    50
    139
    Jul 7, 2020
    AZ
    Spin balance only no centramatics
    Rideandrepair, Siinman, Oxbow and 2 others Thank this.
  8. Big Road Skateboard
    6,039
    32,672
    May 2, 2021
    How often?
    Rideandrepair and Oxbow Thank this.
  9. Lennythedriver
    Lennythedriver Road Train Member
    2,252
    7,537
    Feb 14, 2020
    That’s really impressive because most of the time they end up getting replaced because a chunk gets knocked out of them, or they don’t wear evenly so you gotta replace both. Very rarely do you get to see them run all the way through their full life course. Job well done.
  10. Knightcrawler
    Knightcrawler Road Train Member
    1,599
    5,647
    Apr 10, 2017
    Mpls, Mn oops Ocala, Fl.
    I got about 200k out of mine, but my steer axle clocks in at 10,800. Big motor.
  11. D.Tibbitt
    145,856
    very nice sir. my last truck would've been on its 3rd set in that same time frame. id only ever get about 80k out of them.. but was running alot of offroad and rough conditions.
    Rideandrepair, Siinman, Oxbow and 4 others Thank this.
