The title says it. I would like to know which new trucks are the best ones to drive on the worst winter roads (not concrete) in -40 weather and what parts are most likely to break? I have read somewhere that the old Mack trucks used to be the best trucks for this, but not so much anymore. All input is appreciated, as long as it doesn't veer into some other topic. Hope this thread works out. I respect forums and I only start a thread if really needed, I've searched plenty for a thread like this. Thanks for all the info, I hope it comes pouring in.
tags: "offroad" "off road" "snow"
Most reliable NEW trucks for bumpy winter roads
Discussion in 'Ask An Owner Operator' started by JWilliam, May 6, 2016.
Do you want to be an Ice road Trucker?
Ohboy83 Thanks this. -
Is getting a glider an option?
My vote is Western Star 4900 for new (glider or non-glider)
Kenworth- Heavy spec W900 or T800 if you can get one (Can't speak of the T880)
Peterbilt 389JWilliam and rabbiporkchop Thank this. -
sounds like you are starting new,the words new and reliable do not go hand in hand,and -40 weather if you have no knowledge about it can kill you real quick,do somemore research first is my recomendation
rabbiporkchop Thanks this. -
Whichever one will catch fire the fastest and be the biggest blaze. When the emissions system causes an engine shutdown for some stupid sensor, and you are on a lonely winter road with nobody else, maybe you don't even have cell coverage .... you will think about lighting it on fire for some warmth and also someone might see the blaze and send the cavalry and you will live to see another day ...
My advice would be to look around at what guys are running that have been in the game a while, make notes of how they set their trucks up, and do what they do.
Reason I am asking about a new truck is because I am looking to rent one for a month or so to deliver supplies to the reservations. Is it possible to find someone or somewhere that would rent way older trucks? Seems unlikely but I don't really know, I've never seen older 4 wheelers being rented so doubt it happens much with trucks. What do you think about what kw550cat said?
Also I don't need to get schooled on the cold. I've camped out in the deep north of Quebec in that kind of weather. I have equipment that I will bring in case something bad happens. Just need info on the best newer trucks and if you can suggest something old that would be optimal I would consider buying it. All I need is to work the season then go travel in my camper van the rest of the year, so not big on the idea of buying one unless everyone says that all new trucks will not work in those conditions due to some type of sensor. And speaking of sensors that would disable my truck, any way to disable them?
There are ways to disable them but we don't talk about it around here. And if you are renting, if it breaks down its their problem. I thought you were considering buying. Rent something from Ryder. They always seemed to take good care of their trucks when I drove rentals from them back in my days of being a company driver.
Rent from a specialized company, or a heavy spec truck,
If your really talking -40 and not wind chill. The new emission truck might have trouble with that. The DPF need heat to regen going down the road and engine temp need to be like 190+ for that system to keep working. They claim DEF fluid won't freeze but get slushy and is heated but you never know at -40. You would have to ideal for heat at night I'm guessing and those long idle time are not good for DPF plus the extreme cold at idle will mess emission system up. Better get Glider kit new truck with new rebuilt pre emissions engine 2000 or older year
