Most Reliably/Comfortable Tractor?
Discussion in 'Experienced Truckers' Advice' started by MacgyverIt, Feb 17, 2012.
  1. MacgyverIt
    MacgyverIt Light Load Member
    59
    Dec 23, 2011
    Clayton,Ohio
    Well this post outta get a bunch of diverse replies.:biggrin_255:
    I am considering hauling grain & would like to find out from you guys what would be the best used tractor to look for? During my time on the road in a straight truck I have noticed that Pete's & KW's are much less common to see on the side of the road broke down than say some other trucks. But then again you can get a International with close to the same specs & miles for about 10-15k less. Probably a you get what you pay for thing though.
    While I have yall here what kind of hp do I need to look for 4-500? And gear ratios mid 3's?
    As far as the comfort piece, I guess I will be alright, for the most part I have been driving loud bench seat straight trucks.:biggrin_25513:
    Thanks,
    Jason
  3. STexan
    STexan Road Train Member
    14,963
    29,156
    Oct 3, 2011
    Longview, TX
    Don't think breaking down has as much to do with the name plate on the truck as the engine and how it was/was not maintained. You should maybe be more concerned with weight, engine/drive train specs, and practicality first, then mileage, maintenance history, cost and personal preference.
  4. skein
    skein Bobtail Member
    9
    Dec 4, 2011
    greensboro,nc
    Of everything I have driven I am kinda fond of freightliners. I have also driven,
    Fords
    Volvo's
    Internationals
    Peterbilts (even one that had more then 2 million miles on it)
    and macs
    I prefer 10 gears (5 and 5 with an upper and lower range). I prefer floor heat but top A/c. I despise cab overs. A working cruise control that does not randomly shut off is also nice. Put the #### fuse box easily accessible as well.
    What no one can really prepare you for is how different every one will be. I have been in several that it was obvious they went to great pains to try and make them ergonomic but they just failed completely. Most will have a quirk or two that is just completely irritating.
    Internationals and peterbilts feel cramped somehow. Volvo's have a #### window crank that digs into your leg. The ford had an on/off valve for the heater that you had to crack the hood to switch. Hopefully many of these faults have been fixed by now. Does ford even still make tractor-trailers?
  5. jgremlin
    jgremlin Heavy Load Member
    867
    497
    Apr 21, 2010
    SW Michigan
    Well you have to remember if there are fewer examples running the roads, you're going to see them broke down on the side of the road less often.
  6. spacetrucker88
    spacetrucker88 Heavy Load Member
    Sterling is what used to be a Ford they are owned by Frieghtliner now and gonna be phased out I just read that somewhere.You may despise cabovers but they are usually much lighter so you could haul more weight. I still drive a cabover it is the 7th cabover I have owned. Only ever had one conventional A brand new 1987 LTL9000 ford great tractor but it weighed over 20000 pounds
  7. spacetrucker88
    A T800 Kenworth with a C12 cat engine10 speed direct transmission some where around 355 rears and 22.5 or low profile 22.5 tires and a small bunk or daycab might be a good setup for what you want to do
  8. steelbeltsdrumming
    steelbeltsdrumming Light Load Member
    121
    61
    Jan 28, 2012
    Winona, MN
    Anything built prior to 1/1/2007, pampered its whole life, without any of that emissions garbage on it.
  9. 25(2)+2
    18,756
    45,806
    Sep 18, 2006
    the road less travelled
    Sterling was headquartered and built in Portland, OR and most were built in St. Thomas, ON. The end was announced in October of 2008 and the St. Thomas plant was closed March the next year, with the Portland plant closing in June of 2010. The first Sterlings looked just like the Fords of their last model year(97) except for the emblems. I had to drive one as a short term rental when the leased truck I usually drive was waiting for a part, I didn't care for it but it did the job. They did things differently putting them together. It's odd because some of the lease companies that had them are switching to other manufacturers brands, and dealers carrying Sterling often had a make from a different manufacturer in addition instead of one of the other Daimler brands.
    There are lots of them out there, so we will be seeing them for quite awhile. I even still see some Fords, mostly pulling car haulers.
    I can't address cab overs, only driven a few miles in a couple of them. I have admired many over the years.
  10. Numb
    Numb Crusty Curmudgeon
    4,238
    9,951
    Jan 30, 2012
    Charlotte, N.Carolina
    Volvo's are the most quite ,I have found, and that is important to me.drive one now with the Volvo D13, 500HP (no gov), pulls great. Prefer a Freightliner dash layout, more truck like. bunk area is great though.
    see, it depends on what your gonna do.
  11. Lonesome
    Lonesome Mr. Sarcasm
    11,508
    23,803
    Dec 15, 2007
    Northern Indiana
    PACCAR, a KW or a Pete. JMHO
