Motor Change
Discussion in 'Ask An Owner Operator' started by liljim, Jun 7, 2019.
  1. liljim
    liljim Bobtail Member
    31
    4
    Jul 31, 2018
    How much trouble would it be to change a Mercedes Engine out of a Freightliner 120 Classic to a 12.7 60 Series Detroit
    Rideandrepair Thanks this.
  3. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    The engine swap is easy it's just checking the wiring setup for truck to engine depending on the ecm difference.
  4. mover man
    mover man Road Train Member
    1,698
    1,801
    Feb 21, 2010
    Not a mechanic but when I had a offer of a free ($2500) truck with a blown Cummings engine. Also had access to a totalled truck with a 2 year old det ser60.
    All the mechanics I talked to told me. Can be done but cost will make it not worth it. Something about changing all the wiring, and other things.
    I'd take this question to the mechanics forum.
  5. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    I Know nothing about the mercedes setup, but most changes are possible, BUT if you are going to be paying shop rates for the job. it may not be feasible.
    rollin coal and Rideandrepair Thank this.
  6. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    It's doable. If you have to pay for the work I would advise against it. I know if someone came to me with that swap I would probably turn it away for fear of getting stuck with the truck when the owner runs out of money.
  7. Kshaw0960
    Kshaw0960 Road Train Member
    1,581
    5,025
    Jun 17, 2018
    There’s a few shops that will do it for a few thousand if you have the engine already out of the donor truck.
  8. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    There’s a guy here in Phoenix that does it. Last time I was in his shop he had two trucks in there from United Road, removing the Cummins ISX engines and replacing them with cat C 15 single turbo. I asked him about the cost, and he said about $35K all in.
  9. mover man
    1,698
    1,801
    Feb 21, 2010
    35k was including the engine? If not then that is a tough call to make.
  10. It can be done their are guys who can make you a new harness for transplant motors. Takes a little research and you will find them. And it wont be 35k
  11. rollin coal
    rollin coal Road Train Member
    13,603
    27,966
    Mar 29, 2008
    TN
    Mawk industries will make a new engine harness for about $1800. You can do this for a lot less than $35,000 but it's a lot of digging sourcing and/or having parts made which takes a lot of leg work and time. Besides the harness you'll need new engine mounts, air to air tubes, coolant tubes. The best way to do it cost effectively is if you can source a good known engine cheaply DIY or if you're not doing the work yourself have a trusted mechanic who will without gouging you. But if you're not doing the legwork rounding up parts, pulling engine, sourcing the replacement, forget it because then that $35,000 sounds like it will cover it. In most cases you're much better off just selling the truck as is and buying another one like it with the engine you really want already in it.
