Hi, I have a Mack SXU VISION 2014 with motor D13 MP8.
I have a leak in the exhaust leak with the smell of oil and Diesel
I have checked the head and the turbo, and both are good
Does anyone know what else should I check?
(VIDEO WITH LEAK)
motor D13 MP8. I have a leak in the exhaust leak
Discussion in 'Questions From New Drivers' started by vacaflortoro23, Nov 11, 2020.
You have a leak in the leak?
Diesels dont smel like gasoline, EVER! If you have gasoline it wont run. An oil burn will smell like sesame seeds and have blue smoke.
How often are you checking the oil?
Is the turbo wet on the exhaust side?
An exhaust leak will have black soot at the point it is leaking.
To get the smell into the cab means the leak is in the engine compartment.
Check the EGR line would have been my first guess. The EGR if you have one will be a metal pipe the diameter of your thumb (usually). It goes usually from the exhaust manifold too your intake. DONOT remove this pipe. It has a nasty fine for EGR deletion. Again look for soot at the leak. (black charcoal)
Check the pipe and flex pipe under the cab. -
Turbo is fine and there is not black soot, also the EGR is ok. -
So then it is a matter of checking the mechanics job. It sounds like the mechanic screwed up.
Take it back to where it was repaired and file a complaint. Get the job warrantied -
lovesthedrive Thanks this.
