Motor Question
Discussion in 'Ask An Owner Operator' started by liljim, Jul 19, 2019.
  1. liljim
    liljim Bobtail Member
    24
    4
    Jul 31, 2018
    I have a 2006 International 9900i. I changed the oil 3 days ago and today the low oil pressure started flashing. I pulled over checked the oil and it was full and everything looked fine. I took the oil cap off and it was milky and had either coolant or water under the cap. I did put 2 gallons of coolant in it when I did my pre trip. Is it head gasket or egr
  2. starmac
    starmac Road Train Member
    3,326
    5,110
    Apr 11, 2019
    Fairbanks Ak
    You want me to guess or just tell you what ever it is you want to hear??
    There is no way to tell from this end.
  3. Rubber duck kw
    3,189
    5,844
    Dec 9, 2017
    Could be either of those or could be leaking liner orings or maybe an oil cooler but those usually get oil in the coolant not the other way around I think.
  4. liljim
    24
    4
    Jul 31, 2018
    Thanks for your reply! I know you don’t know, I was only asking for for opinions . I have been told several different things
  5. starmac
    3,326
    5,110
    Apr 11, 2019
    Fairbanks Ak
    It can be several different things, HOPEFULLY it is the cheapest.
  6. tnevin225
    tnevin225 Heavy Load Member
    920
    1,133
    Jan 1, 2014
    Put some Lucas in it and get it to your favorite shop. Hopefully you caught it fast enough that it didn't do much damage.
  7. stayinback
    stayinback Road Train Member
    3,195
    5,203
    Jan 24, 2014
    chicago,il
    Hope for the easier things...Does the water pump weep internallly? What kind of motor?
    Hope its only a pump or a bad compressor-
  8. liljim
    24
    4
    Jul 31, 2018
    It is a Cummins isx
  9. starmac
    3,326
    5,110
    Apr 11, 2019
    Fairbanks Ak
    It is up to you, but I have been around the block a few times, and if the oil is milky, I wouldn't be driving it anywhere at all.
  10. MartinFromBC
    1,804
    7,960
    Oct 19, 2018
    You had to add 2 gallons of coolant, but started it up anyway. I would have looked for leaks, and if none, instantly pulled the oil pan plug.
    Yikes!
    Get it TOWED TO A SHOP
  • Draft saved Draft deleted
