MotorKote on Cummins ISX?
Discussion in 'Experienced Truckers' Advice' started by JohnSmith69, Sep 15, 2020.
Thread Status:
Not open for further replies.
  1. JohnSmith69
    JohnSmith69 Light Load Member
    64
    29
    Feb 23, 2020
    Can I use motorkote on my ISX? Will it help with the oil consumption? Thanks
    truckdriver31 Thanks this.
  3. Ridgeline
    22,368
    116,046
    Doubt it would help, maybe time for rings.
  4. AModelCat
    158,527
    Doesn't Cummins have a special oil developed to help remove carbon packing on the rings? I'd put more faith in what is recommended by the engine manufacturer over any snake oil additives.
  5. Dockbumper
    Dockbumper Road Train Member
    3,778
    9,860
    Apr 29, 2020
    Inframe beats motorkote every time. Don't you OO's make the BIG BUCKS!? All of us company drivers just work for chump change.
    Snailexpress and truckdriver31 Thank this.
  6. kwswan
    kwswan Road Train Member
    1,939
    10,253
    Jul 26, 2009
    mcminnville,tn.
    It won't do anything but make a mess if you put it on it. If you put it in the engine it might help.
  7. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    Made by valvoline, Cummins sells in at the Cummins shops
    KB3MMX and truckdriver31 Thank this.
  8. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    motorkote is not a thick oil. its super thin. lucas would be a better choice.
  9. Colt6920
    Colt6920 Light Load Member
    177
    260
    Apr 28, 2017
    I would not use any oil additives.
    Major producers spend ridiculously large sums of money each year on R and D. Doubt some random snake oil will be better than that.
    Like others have said, go get the special Valvoline Premium Blue Restore oil from Cummins specifically engineered by Cummins and a major oil company to solve your issue. Get the recommended filter as well. The oil is unfortunately somewhat expensive, however it has some pretty exotic ingredients that drive the cost way up. Make sure you get the Restore, they have like Extreme but thats not the one.
    Otherwise you are looking at a rebuild.
    AModelCat Thanks this.
  10. pushbroom
    pushbroom Road Train Member
    1,779
    7,312
    Sep 1, 2012
    Root issue is carbon packing. Pistons/ liners need to get updated to arp style liners.
    Vavoline did have a special oil to fix/ patch the issue, it has since been discontinued.
    Dave_in_AZ, D.Tibbitt, KB3MMX and 2 others Thank this.
  11. Ridgeline
    22,368
    116,046
    They should make enough for an inframe,
    Snailexpress Thanks this.
  • Thread Status:
