Mounting in a headliner?
Discussion in 'CB Radio Forum' started by Sodman, Mar 23, 2013.
  1. Sodman
    Sodman Bobtail Member
    28
    South, LA
    I was planning on mounting my General Lee in the headliner hole in my International 4300...
    Was thinking I'd just get some foam and put some under and above it to hold it in tight... but the more I think about it, there 's the cooling aspect and the fact that it won't be "bolted" down.
    How do people normally mount a radio in a headliner?
  3. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    Aren't there provisions in the hole for you to add straps?
  4. Sodman
    28
    South, LA
    Honestly, maybe there is... I haven't looked that closely at it...
    Now you mention it, there seems to be some holes at the bottom... maybe mount the bracket to the bottom?
  5. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    Unless YOU own the truck, I would not make a permanent or even semi-permanent mount. Use of straps means you can pull it out easily, if someone else uses the truck.
  6. Sodman
    28
    South, LA
    It's my truck.
  7. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    OK, in that case it would be a good idea if you can go ahead and mount it with it's bracket. Do you have a power and antenna connection in there already?
  8. Sodman
    28
    South, LA
    There's a power and ground, best I can tell, straight from the battery. Still working on the antenna and its coax.
    If I want to ground the antenna, do I just solder something like a 12 gauge wire to the ground on the antenna and run to the chassis?
    Still open to suggestions and tips on the headliner install...
