Moving Cross Country in a '24...help!
Discussion in 'Questions To Truckers From The General Public' started by jdanielz79, Jul 9, 2009.
  1. jdanielz79
    jdanielz79 Bobtail Member
    Jul 9, 2009
    ny,ny
    HI EVERYONE. I'M NOT A TRUCKER, BUT MIGHT CONSIDER MYSELF ONE AFTER MY MOVE FROM NYC TO PORTLAND OREGON IN A 24' TRUCK! JUST WONDERED IF ANYONE HAD ADVICE AND MAYBE SIGNALS THAT WOULD HELP ME INTERACT WITH YOU GUYS. I'M DRIVING WITH MY HUSBAND AND 6 MONTH OLD DAUGHTER, SO I'M JUST SCARED ABOUT SAFTEY.
    -JDANIELS79:biggrin_2554:
  3. dlngr
    dlngr Bobtail Member
    28
    5
    Oct 27, 2007
    Oglesby Il
    You're gonna DRIVE a truck that old that far???
  4. DozerCowboy
    DozerCowboy Light Load Member
    125
    64
    Jun 8, 2009
    Port Saint Lucie, FL
    i think she meant a 24' truck ...... ha ha ha
  5. jdanielz79
    Jul 9, 2009
    ny,ny
    whoops! yea I screwed up. I meant 24'.
  6. Allow Me.
    10,704
    12,355
    May 28, 2009
    Rancho Mirage, Ca.
    :biggrin_25516:You're probably driving a u-haul rental. Don't think for a minute that you're a truck driving fool. Just plug along in the slow lane and mind your manners. For kicks, buy a C/B radio and plug it in to the cig lighter (ch 19) and you can talk to truckers. Get a cheapie at radio shack for $50 plus an antenna. If you're renting a U-haul, check all your engine fluids before you even start it up. Sounds like a fun trip, don't do the drive all day/night thing, you'll just wear yourself out. :biggrin_25516:
  7. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Just keep it slow until you get adjusted to the truck. Before you start driving every day check the truck over to make sure it's safe. Check your tires to see if any of them are flat. Make sure you have a U-Haul book so if you have problems you'll have the phone numbers to call. Lock your back door with a good lock. Don't push driving everyday. You should be able to make 500 miles a day if you don't stop alot. Be real careful about driving fast even if the speed limit is 70 or so. Make sure you get a book on the motels or hotels you plan to stop at night. I've done cross country self moves 4 times and you should plan on stoping early everyday so you don't burn out the family. We stayed at Hampton Inns across the country and they are ok.
    I never stopped at the scales on any of the trips and never had a problem with it. But those trips were years ago. But if the sign says you have to pull in then you'll have to do it. Just take your time and plan the trip out so you'll know where to stop. You'll do just fine and don't let any other driver push you if you feel it's unsafe.
  8. TripleSix
    131,707
    Dont buy a CB.
    Just make sure the truck is in good running order, and keep your cell phone charged. Dont make your husband nervous by yelling and if you get nervous, sing to your baby. Baby and hubby will appreciate it.
  9. TripleSix
    131,707
    And avoid going into any rest area that you cant see from the interstate. Avoid all rest areas at night.
  10. Allow Me.
    10,704
    12,355
    May 28, 2009
    Rancho Mirage, Ca.
    One additional piece of advice. Be aware of the overhead clearance on the U-haul truck. Building overhangs, tree limbs, fast food drive-thrus etc will ruin your day and empty your wallet.:yes2557:
  11. Powell-Peralta
    Powell-Peralta Road Train Member
    1,585
    240
    Jul 17, 2007
    Too dangerous. Too risky.
    My advice would be to use ABF's moving service---basically the same as what you're planning except they supply and drive the truck. You still have to load/unload. And just fly, take a train or drive your car and relax.
    Pls refer to the post about axles falling off also in this section.
