moving inverter between trucks
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by driverdug73, Jan 25, 2012.
  1. driverdug73
    driverdug73 Bobtail Member
    13
    8
    Jun 18, 2011
    Fulton Mo
    Does anyone know of a good way to transfer a inverter from one truck to another? I move between divisions once a year and would like to transfer my inverter with me. I'll have the shop install it, a 1500 watt cobra, but would like a simple way to move back and forth. Ideas? Thanks.
  3. Omniscient
    Omniscient Light Load Member
    139
    31
    Jun 9, 2011
    The lost Highway
    Well I just mount mine in the side box. Drill 2 holes into the bottom with grommets and run the positive and negative through to the batteries. Then put caulk around the grommets to seal it off. Then again that only helps if you can get wires leading into the sleeper.
  4. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    If it is a company truck their shop would have to do the work. This covers you in case the inverter is not connected correctly and it burns down the cab.
    Thanks,
    Mark
