Moving my machine shop to AZ
Discussion in 'Questions To Truckers From The General Public' started by cimdave, Jan 9, 2017.
  1. cimdave
    cimdave Bobtail Member
    Canandaigua, NY
    I currently live in Canandaigua, NY (20 mi SE of Rochester) and am planning on moving to Chino Valley, AZ (10 mi N of Prescott) sometime in the (hopefully)near future. I have a small machine shop in the back of the house, and I plan to move the equipment as well.
    (I will use a one-way rental to move my household.uhaul or budget)
    Just as a wild guess, maybe 30,000# of stuff for the shop
    I can do my own rigging, which is good, cuz riggers cost big bucks around here
    But I'm 62, and I doubt I can load/unload a trailer in one day. Because of the way things are,
    I estimate giving myself a week. (need to load out the big stuff to have room to pack up the smaller stuff.)
    All the semi trailer lease/rentals appear to be round trip only, no one-way.
    I'm guessing that hiring an independent o/o might be my best bet for pricing and flexibility (both parties)
    (I might be wrong on this.)
    Wouldn't be a real tight schedule, just predictable delivery date.
    Alot of things aren't clear about all this. (I will gladly follow links cuz that's easier than you typing)
    1. How do I find and hire a truck? This message board, broker, whatever?
    2. Is having the trailer sit a week at each end possible? Who provides it?
    (Uncertain alternative, send a rent/leased trailer back home somehow? Scary.)
    3. Can heavy machines be adequately secured inside a van? Or is a flatbed required?
    (I unloaded machines from a van, they were on skids, packed tight to the front)
    4. On or off pallets?
    5. Getting trailer to my current location, and pickup the empty at the other end?
    6. How to Estimate costs
    7. Who knows what I have overlooked here. :)
    I worked for machine tool dealers and builders, and have loaded/unloaded a lot of trucks over the years.
    I also traveled all over western NY visiting shops and factories, and shared the road with you folks.
    No complaints...... except this one crazy in CT. :)
    All the industry has moved out of NY
    Time for me to do the same
    Thanks in advance for any advice you can give
    dave g
  3. Ridgeline
    22,558
    119,438
    I would call a rigging company and ask them but if they can't give you an answer, call landstar. One of my trucks did a move like this back in October, PA to NM.
    The costs, it wasn't cheap.
  4. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    If you are doing it yourself and you want it to sit for a while for the loading? Agreed it wont be cheap.
    Have you thought about getting a "Pod"? I have seen on This Old House shows where a family moves their possessions into a box that is landed on your property. It is loaded then the truck returns and loads the box for hauling/storage.
    Another possibility would be to get a shipping container. Fill it then get it transported to where it can double as a future machine shop.
    I am only speculating here. That 30k weight is pretty much the extent of a normal load. Also some of that machinery may be too heavy for a normal box load. Vans that haul paper rolls around usually have reinforced floors with extra cross braces to resist the load going through the floor.
    One last question, completely off topic. Are you a live steamer? Not that it matters with your quandry.
  5. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    Personally I would go the the route of the shipping container. Just keep in mind you need to arrange for a means of putting it on and getting it off.
    lovesthedrive Thanks this.
  6. Aradrox
    Aradrox Heavy Load Member
    900
    622
    Jan 21, 2016
    Do you own a forklift? If not maybe you can rent one? My main point is how do you intend to load unload this heavy equipment as it may I influence your options.
    I remember watching a show about Hotshots moving odd things from point a to b not sure onax weight a hotshot could haul but would imagine 30k would be to much but maybe they are less then half the cost. Just some food for thought from someone that just swings door and did a bit a flatbed drywall hauling
  7. Aradrox
    900
    622
    Jan 21, 2016
    Also can a 53ft trailer access your house another question to consider
  8. Studebaker Hawk
    Studebaker Hawk Road Train Member
    3,010
    9,797
    Oct 18, 2010
    NW Indiana
    This is a commercial move. Call a local household agent, NAVL, Allied, United, your choice. One with agents near both ends. They will arrange to leave a trailer in your driveway, assuming it fits. You load and secure it, they take no responsibility for damage. If it loaded overweight you will have to reload it before it goes anywhere. You are getting "exclusive use" of the van so it is not a typical weight x's mileage HHG move. They will charge you x number of dollars each day it sits in your origin and destination and x amount for the movement. They will probably turn it loose to a power only company like ours to do the actual mileage between the points, but that is not your concern. They will be happy to give you an estimate of the move no charge.
    I recommend you do it during the "off season" HHG companies are busy during the May-Sept time frame. You will get a better rate if you do it other than then and if you give them as much time leeway to move the trailer as you can. The tighter you specify times, the more money you are going to pay.
