Moving switches in a Volvo 780
Discussion in 'Experienced Truckers' Advice' started by Midnightrider909, Jan 11, 2018.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    8F707126-3597-4C96-A687-0C1CFEF6BEE4.jpeg I’m set to buy this truck soon and I need a place to put my QUALCOMM. When mounted the QUALCOMM will block the four switches on the right as that is the only space where it can really go. Does anyone know if it is easy to move the switches on the right over to the blank spots to the left of the vent?
  3. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    The tan molding strip that's underneath the switches can slide to one side and then be pulled out. It might pull out and then slide, I don't really remember the order. Then there are screws revealed on the bottom of the panels. I think there are also plastic tabs on top of the panels that you press in to remove the panels. These tabs might be easier to access by removing the fuse panel and the smaller one to the left of it.
    I'm not sure if the wires will reach that far, but now you can at least check for yourself. This will also help familiarize you with working on your own truck, in case you want to add more switches or fix an air leak behind the dash valve.
    Midnightrider909 Thanks this.
  4. Balakov100
    Balakov100 Road Train Member
    3,937
    2,636
    May 10, 2012
    Temple, TX
    I wouldn't even worry about those switches. Unlikely you will use them all that much.
  5. loudtom
    1,717
    2,800
    Aug 26, 2016
    I use the hill start assist button all the time to cancel it. It tends to want to activate at traffic lights or even on flat ground when I come to a stop and put it in reverse. I wish it would remain off and I could use the switch to activate it, since I've only needed to use it one time. The rest of the buttons I rarely use.
    ladr Thanks this.
  6. Michael H
    Michael H Medium Load Member
    466
    1,023
    Nov 3, 2015
    Arizona
    I moved all the dash switches on my volvo 670. A couple of the wires end up fairly tight, but it's completely doable. It was nice to group the switches in the order I wanted them.
    Scooter Jones Thanks this.
  7. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    If you're buying that truck new, tell em you want it that way. They want the sale they can move them for you.
  8. Ridgeline
    22,154
    113,625
    Midnight, have the dealer move the switches where you want them to be, they should have no issue with it when they do the new truck prep and inspection.
