moving tandems all the way forward
Discussion in 'Questions From New Drivers' started by 4noReason, Sep 22, 2013.
  1. 4noReason
    4noReason Road Train Member
    2,375
    731
    Nov 29, 2012
    i do this all the time....then someone told me i can get a ticket. i sure dont remember my trainer even telling me that. what if my weight makes me move it all the way forward
  3. 25(2)+2
    18,749
    45,457
    Sep 18, 2006
    the road less travelled
    You can get a ticket in Maryland for sure, not sure about anywhere else. Too much overhang determined by a formula.
    A heavy load too much in the front can't always be made legal by sliding them up, either. Load distribution is important, and so is checking the weights if you aren't sure.
  4. J_FROG
    J_FROG Road Train Member
    1,061
    564
    Sep 4, 2011
    49 states and Canada
    As long as your weight is legal going all the way forward should not be a problem in any state. Its all the way rearward that will create a problem. Some states like TN have a 41 foot rule. CA is even shorter. Refer to your RM atlas for the specifics on each state.
    Be sure to keep in mind the overhang rule also. If your trailers allow you to go too far forward.
    pattyj Thanks this.
  5. HORIZON2819
    HORIZON2819 Bobtail Member
    48
    14
    Nov 26, 2012
    Toronto,ON
    Dont think about ticket... Think about load distribution.. Uneven distribution of load will make it harder to stop promptly and can be dangerous too.
    pattyj Thanks this.
  6. 123456
    123456 Road Train Member
    10,555
    5,746
    Oct 22, 2010
    32179
    1 good answer anyways.......
    thanks Staff
  7. 4noReason
    2,375
    731
    Nov 29, 2012
    thx guy sounds good. i scale my loads to make sure im legal. but sometimes i move them when i go in the city to turn wider.
    fr8te_sh8ker and 25(2)+2 Thank this.
  8. Hammer166
    7,413
    26,779
    Aug 18, 2007
    ~8600+' and loving it!
    Here's the Maryland reg:
    53' trailers allowed only on Interstate routes in National Network and on Maryland State Highway Designated Routes. Trailers in excess of 48' require no more than 41' spacing from
    kingpin to center of rear tandem and can have no more than 35% of that distance as overhang measured from the center of the rear tandem to the end of the trailer.
    If you do the math, 35% of 41' is 14'4". Most kingpins are 36" back, so the center of tandem is 44'. That's 9' of overhang, no problem. But if you shorten up to 37' (Do 53' go this short? been awhile...) or less, you get over the overhang limit.
    25(2)+2 Thanks this.
  9. snowwy
    snowwy Road Train Member
    20,531
    13,267
    Jul 6, 2009
    the front axle on my trailer is 36. the rear axle is 40 or 46.
  10. STexan
    STexan Road Train Member
    14,963
    29,153
    Oct 3, 2011
    Longview, TX
    I don't like backing with the tandems anywhere near all the way forward, especially into tight spaces. You slide trailer tandems all the way forward all the time, eventually it's going to bite you.
    mclass555 and 123456 Thank this.
  11. white wolf
    white wolf Light Load Member
    287
    131
    Jul 1, 2013
    minneeessoooota
    The 41 foot rule is correct and thats a federal rule and yes some 53 foot will slide that far now but most drivers will only slide that far forward when they are having a difficult time with the area like inner city drops but the minute I would get out of town I would pull off and slide them back for weight distribution and ride comfort
