I’m only getting 6 mpg at 65 mph 1200 rpm. My truck is geared at 2.85. Any ideas? The only time I get 7 mpg or above is at 1000 rpm 58 mph.
Mpg 2019 cascadia dd15 dt tans
Discussion in 'Ask An Owner Operator' started by Texasrig, Mar 5, 2022.
What type of wagon do you pull?
What was it before? Any major changes done before the drop?
baha Thanks this.
you have to eliminate that list to see what the issue is. -
Check the basics, no boost leaks anywhere. Check for black soot all around the manifold/turbo. Pressure check CAC (charge air cooler) if you can. A boost leak will make a high pitched squealing noise.
Check engine light on, any codes?
Also with the winter blend fuel it's down about roughly .5-.75 maybe even a hair moreNorth Pole Nightmare and LoneRanger Thank this. -
I get 6.5-7mpg but usually weigh in around 73-80k gross.
