So I'm having problems with my mpg I drive a t660 its hot out so I got to idle... But I keep getting warnings on my mpg.
Any other drivers got this problem or any tips to fix this
MPG issues at Con-Way
Discussion in 'Con-Way' started by TruckerPete1990, Jul 16, 2012.
Page 1 of 6
Slow down. I assume your truck is not equipped with an apu. If you are being called and warned about your fuel consumption tell them to put you in a hotel and then you wont have to idle because of temperature issues!
Haven't had chance to do 62 lol I'm getting tight loads plus had two blow outs in two days didn't help lol
Just curious, but do you also have out of route miles? I'm running Texas regional and idle some days more than I drive, my mpg hadn't been mentioned thus far. Of course temps exceeding triple digits before the heat factor I'd even brought into it might also be part of the reason. Its already 80 with a heat index of 88 at 10am
My out of route miles are 3% they said which is good
Plan on that if I get a 2 nd warning.. just got to find a company most I want have to be 23 lol only 22 started driving when I turned 21...
if you switch to the freight side instead of truckload you can be home daily and make 6-900 take home weekly
Shift at lower rpm's, use cruise at 61 or 62, turn truck off when you go into the store, turn it off when you bump a dock and go for a walk. Turnn it off when you wake up until it is time to pull out. That's the coolest part of the day. I assume you are doing all those things right and more based on your answers above. Get that truck to the shop.
greeneyed Thanks this. -
We got no openings in my area for fright. And I do all that well I run 65 a lot gonna keep her at 62
Page 1 of 6
