mpg
Discussion in 'Questions From New Drivers' started by jethro712, Nov 20, 2019.
  1. jethro712
    jethro712 Medium Load Member
    604
    6,035
    Aug 31, 2014
    ok folks, was told by a non driver that due to winter blend diesel & colder temps that my mpg will be lower. if its true, how much of a difference?
    thanks in advance.
  3. Anywhichwaybutloose
    Anywhichwaybutloose Light Load Member
    157
    263
    Jun 24, 2017
    It all depends on the blend. Usually it comes out to 10-15% less.
    Lepton1, jethro712 and DUNE-T Thank this.
  4. 201
    201 Road Train Member
    12,431
    25,426
    Apr 16, 2014
    high plains colorado
    I always noticed a drop in power and mpg when the blended fuel came out, on older trucks, anyway.
    jethro712 Thanks this.
  5. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    4% of the drop is due to winter fuel blends having less BTU. The rest is due to weather and temperature. Cold air is denser than warm air and takes a lot more energy to push through.
    D.Tibbitt, Lepton1, Roberts450 and 3 others Thank this.
  6. King Michael
    King Michael Light Load Member
    89
    72
    Nov 20, 2018
    Untreated diesel fuel begins to jell at 17.5 degrees.
    If you are idling (overnight) and the temp drops to let's say 10* you ain't gonna jell up... Because your return line is heating your fuel in the tanks.
    If you are driving, it is just as unlikely to happen.
    If the truck is sitting for a day or two, with untreated diesel and the temp drops . .. You got problems .
    Most larger truck stops treat their diesel.
    Regular diesel is #2
    Extreme weather diesel is #1
    Yes, you will get slightly lower mpg with treated diesel. Barely enough to notice. #1 you will notice significant drop
    Best thing to use, (this is 30years experience) is the white bottle of diesel power service . It prevents jelling and increases cetane rating which equates to better mpg
    jethro712 and Frontman Thank this.
