MPG
Discussion in 'Ask An Owner Operator' started by bigtruckisgood, Jul 22, 2007.
  1. bigtruckisgood
    bigtruckisgood Bobtail Member
    8
    Hello.I'm wondering what a deference would be in MPG between city and hwy driving.For example 4.5mpg city and 6.5mpg hwy driving .Is it sounds right or not.I'm talking about the big rigs of course and rough estimate of mpg.
  3. Pur48Ted
    Pur48Ted Road Train Member
    3,643
    5,979
    Jun 14, 2006
    Grand Rapids, MI
    I had a DDEC read-out in my truck. I could re-set it for testing purposes. Once I re-set it to test MPG in City VS. Highwy driving. My City MPG (stop lights, speed limts of 35MPH ect) was less than 2.2, while my Highway MPG was over 6.9. (Same Load)
  4. ramifuel
    ramifuel Bobtail Member
    14
    lakeland ,fl
    if you put the pill in you tank you be getting up to 8mpg on the hwy like ime, i went from( 6.2-6.4) to 7.2 and now 8.0mpg alot of drivers
    are going to talk negative but that is only cause they dont got the balls
    to try it out especially the one with the photo of him and his girlfriend
    kw 470
  5. 25(2)+2
    18,749
    45,401
    Sep 18, 2006
    the road less travelled
    It depends on the type of city driving, if you ran so you made most lights, it would be pretty good, if you stop at every one it will be terrible. Some trailers pull harder than others and speed makes them worse. It also depends on how fast you drive on the highway. When I was running a Cummins with a 9 speed there was very little difference unless I kept it under 55 on the highway.
    Timed lights are pretty easy in light traffic, the smart lights are hard. Those change whenever someone approaches from a side road.
    Heavy traffic with heavy loads makes highway use higher as well, you need to change speed often to keep safe distances from other vehicles.
