MPH off after switching to low pro 22.5s
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Slow302, Sep 8, 2023.
  1. Slow302
    Slow302 Medium Load Member
    348
    117
    Jul 12, 2013
    MO
    I have 1999 KW T2000 with Cat 3406E 13 speed that came from the factory on low pro 24.5" tires. Since 24.5" tires are harder to find i switched to low pro 22.5" tires. Now speedo is 2 MPH off. It shows im doing 70 MPH when im actualy doing 68 MPH. Also odometar shows about 3% more miles. So whats fix, different speed sensor or reprograming ECM ??
    KB3MMX and blairandgretchen Thank this.
  3. Big Road Skateboard
    6,174
    33,864
    May 2, 2021
    Set tire revs in ECM. Revs are different between 24.5 and 22.5
    KB3MMX, Magoo1968, Oxbow and 2 others Thank this.
  4. Slow302
    348
    117
    Jul 12, 2013
    MO
    Local CIT KW in St louis MO cant do s**it with Cat ECM. Ill have to call cat and see if they can do it
    Oxbow Thanks this.
  5. Big Road Skateboard
    6,174
    33,864
    May 2, 2021
    Any independent shop with a laptop should have the ability. It's a single simple parameter change, takes literally minutes
    KB3MMX, Magoo1968, Oxbow and 1 other person Thank this.
  6. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,693
    16,281
    Jan 18, 2011
    Unfortunately with an e model cat it’s a mathematical equation instead of a quick parameter change
    But anyone w/laptop and right model software can do it
    I just can’t remember the equation
    KB3MMX and AModelCat Thank this.
  7. AModelCat
    158,881
    Diesel Dave Thanks this.
  8. rollin coal
    rollin coal Road Train Member
    13,280
    26,786
    Mar 29, 2008
    TN
    11R22.5 tires are the same overall diameter as lopro 24.5 but yeah you already got the lopro 22.5's.
    KB3MMX, Magoo1968 and Oxbow Thank this.
  9. Diesel Dave
    8,714
    24,937
    Jan 20, 2010
    Hesperia, Ca.
    I’m surprised you remembered :D. I did go through a process. I played with the CAT E.T. for awhile then figure I had to play with the “Dip” switches on back of the speedometer head to get it right. There’s a thread on here about it, but it’s been awhile.
  10. lester
    2,920
    7,889
    Jan 2, 2012
    NW, Iowa
    For just your speedo to read right you just need to change the dip switches on the back of it. Any decent service guy should be able to help with that. It's just a bunch of small switches on the back of speedometer.
    Your ecm might read different but does that really matter?
    I believe this information to be correct. I did this on my 01 pete with cat
  11. Big Road Skateboard
    6,174
    33,864
    May 2, 2021
    I'm not sure guys, but i thought most T2 speedos were ECM driven.
    Been a long time since I've messed with one though
