mud chains/seat cushions?
Discussion in 'Questions From New Drivers' started by copperdome, May 11, 2020.
  1. copperdome
    copperdome Light Load Member
    80
    100
    Oct 10, 2019
    I'm not really new, but I have a couple newbie questions... first thing is... if regular chains didn't get me out of the mud earlier, would "mud chains"? I don't think I do enough driving in the mud to justify mud tires. Also... I'm tired of the hemorrhoids, what can I do?
  3. SoulScream84
    3,426
    26,276
    Mar 21, 2020
    Dont use the chains for wiping, I've never heard of "mud chains" chains are chains.
  4. Numb
    Numb Crusty Curmudgeon
    4,228
    9,921
    Jan 30, 2012
    Charlotte, N.Carolina
    'roids can be removed.
    best thing I ever did. should have done yrs before. they were bad.
    copperdome Thanks this.
  5. buddyd157
    buddyd157 Road Train Member
    13,582
    34,896
    May 25, 2017
    under a shade tree
    i think your main problem is, the air in your tires. you should have switched to the lighter summer air by now. the heavier winter air is what is making you sink into the mud.
    you need to take care of that.
  6. AModelCat
    161,476
    Good set or 2 of triple 8 mil Tryggs. Good to go.
  7. LDLWells
    LDLWells Heavy Load Member
    782
    1,218
    Jan 14, 2019
    Two types of chains I've seen. Could be more could be less and I'm hallucinating. First you have the round cheap ones you pick up at the hook. Those are great for the highway when "chains are required" the others look like your normal chains but the links are square. That's what I've always heard referred to as mud chains. They work well and are typically lighter. The secret is to put the chains on before you get stuck
  8. copperdome
    80
    100
    Oct 10, 2019
    Any kind of cushion or suggestion I could do in the meantime?
    In regards to where I unload in the mud, the last couple times I took a couple shovel fulls of the dry dust I haul and packed it in under the tires, it worked like a charm I pulled right out.
    Numb Thanks this.
  9. Numb
    4,228
    9,921
    Jan 30, 2012
    donut type cushion.
    there are inflatable and regular pillow kind.
  10. okiedokie
    okiedokie Road Train Member
    13,372
    104,192
    Jun 13, 2011
    PNWET
    Rutin 500. The off road answer to the truckers nightmare.
