Mud & snow switch ?
Discussion in 'Ask An Owner Operator' started by 2hellandback, May 3, 2008.
  1. 2hellandback
    2hellandback Heavy Load Member
    978
    237
    Dec 19, 2007
    Blackfoot Idaho
    My 2003 T-600 has a mud and snow toggle switch ! When push up on the switch and let go it returns to its original position. Can any one explain how this mud and snow switch works or what this is for and how it functions ? Or how and why i would use it?
    Thanks !
  3. Chillwag
    Chillwag Light Load Member
    161
    32
    Nov 9, 2006
    Vancouver, Wa
    Sounds like the switch may be bad if it returns to the original position when not held. It's either an inter axle lock or an axle lock. If the later use caution when using since an axle lock will cause your drive axle to act like a solid axle and will not allow one side to turn faster than the other. So on dry pavement you could loose some of your steering response.
  4. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    which is why it's a temporary contact switch meant to be used as an emergency thing and not let ingaged
  5. Chillwag
    161
    32
    Nov 9, 2006
    Vancouver, Wa
    I would rather have a light on the dash, remember if this engages during spin-out (IE: one wheel spinning and one not) you can count on damage. It's kinda live popping the clutch on one wheel.
