Multi-purpose rig...
Discussion in 'Questions From New Drivers' started by Papacranberry, Jul 30, 2023.
  1. Papacranberry
    Papacranberry Bobtail Member
    12
    Hi, all! I have an idea for taking a 24' flatbed straight truck and strapping a 20' conex on it to use for dry box loads, so that if I need a flatbed, all I have to do is remove the conex. Is this common practice? Do y'all know of this being done?
  3. Blu_Ogre
    Blu_Ogre Road Train Member
    8,455
    50,464
    Jul 14, 2013
    Out west
    20 ft shipping containers run about 5500 pounds (24 ft about 5800).
    Considerably heavier than a generic freight box.
    May only be practical if you only haul lite weight stuff.
  4. tscottme
    tscottme Road Train Member
    Dropping a conex at some random town is going to cost you. If you plan to only change from flatbed to box truck at home, better. You need to follow the rates for flatbed straight truck & van straight truck to know if your idea makes sense.
    Papacranberry and rockeee Thank this.
  5. wis bang
    wis bang Road Train Member
    3,454
    4,098
    Jan 12, 2011
    Levittown, PA
    I've been seeing contractors using the swap body concept which is common in Europe.
    The truck chassis is similar to a roll off trash container and they have multiple bodies set up for different purposes.
    Custom built with weight laws/cargo capacity in mind and most likely too costly as a one off setup
    Papacranberry and beastr123 Thank this.
  6. 201
    201 Road Train Member
    12,753
    26,228
    Apr 16, 2014
    high plains colorado
    I think you are talking about a "Drom Box". Years ago, many outfits that did long distance deliveries, had long wheelbase tractors, with a freight box behind the cab. Many municipal companies have half flat bed/half dry box trailers. I wouldn't mess with a straight truck, though, you'll run out of room pretty quick.
    Papacranberry Thanks this.
  7. Lexuslane
    Lexuslane Medium Load Member
    496
    1,009
    Oct 22, 2021
    Yeah
    A concrete finishing company near me does that
    They have a 10 wheel truck that appears to be a former rig used for toll off trash containers , , and they use flatbeds with all their concrete forms on them , they drop them at job sites for a couple of weeks .
    You’d need a lighter weight box than a conex .
    Cargo boxes are just an aluminum skin to keep the rain off .
    Papacranberry and wis bang Thank this.
  8. wis bang
    3,454
    4,098
    Jan 12, 2011
    Levittown, PA
    Some of the dromedary boxes were for cargo separation; explosives needed to be separate from the detinators so the larger explosive compounds were in the trailer and the smaller blasting caps in the Drom to meet the requirements.
    Oxbow, Papacranberry and 201 Thank this.
  9. Allow Me.
    10,766
    12,573
    May 28, 2009
    Rancho Mirage, Ca.
    I could be wrong, but I don't think it's legal to "strap" a loaded container to a flatbed truck,research that.
  10. D.Tibbitt
    156,803
    probably be in it for less time money and headache to just own 2 different trucks
    AModelCat, Papacranberry and tscottme Thank this.
  11. Ridgeline
    22,723
    123,043
    It is not common and it is not really good.
    I won't get into the problems with it, but I will say that with 24 foot of real estate, you should be able to find a segment and run it.
