'Must Have' Tools
Discussion in 'Experienced Truckers' Advice' started by Highway Hypnosis, Mar 6, 2017.
  1. Highway Hypnosis
    Highway Hypnosis Light Load Member
    144
    135
    Apr 12, 2014
    Minot, ND
    Probably the best tool I have right now in the oil field:
  3. Highway Hypnosis
    144
    135
    Apr 12, 2014
    Minot, ND
    Here are a couple more that can save a lot of down time:
    [​IMG][​IMG]
    Lepton1 and OLDSKOOLERnWV Thank this.
  4. Chinatown
    Chinatown Road Train Member
    77,045
    179,953
    Aug 28, 2011
    Henderson, NV & Orient
  5. Highway Hypnosis
    144
    135
    Apr 12, 2014
    Minot, ND
    Something to put over the check engine light eh
  6. Chinatown
    77,045
    179,953
    Aug 28, 2011
    True, I kept a piece of black electrical tape over that light.
  7. Ridgeline
    22,642
    120,741
    Nothing other then the phone number for road service - if you are a driver.
    Ryan423 and Velli Thank this.
  8. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    That's absurd. Would you really rather your drivers call road service over simple problems that any monkey could fix?
  9. Raezzor
    Raezzor Quis custodiet ipsos custodes?
    1,412
    1,186
    Aug 1, 2009
    Columbus, OH
    A good multi-unit mechanics set. Should contain various english and metric ratchet sockets, a set of screwdrivers, preferred to have an electric cordless drill/driver too. Also a hex wrench set, a good one. And a chisel for those #### rivets in lights. Of course a good flash light, and a decent sized hammer (3-4lb at the least...) Crowbar, broom (for dry van/reefer,) and a good knife as well.
    Highway Hypnosis Thanks this.
  10. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    That all depends. A vast majority of "drivers" these days don't have the slightest clue what each of those components they memorized the name of (and are supposed to be checking to make sure they aren't "cracked, broken, or missing") LOOK like, let alone how they operate...and if you don't have an understanding of how something works, it is darn near impossible to figure out why it isn't working or how to either SAFELY bypass it or rig something together to make it work well enough to SAFELY get back to a shop. Believe it or not, there are "drivers" who don't even know how to change a #### headlight bulb, and I sure as hell wouldn't want them attempting to turn a wrench on MY truck. The average driver might (if you're lucky) be able to tell you more than just "the truck broke...send someone to fix it"...actual details about WHAT broke or what parts should be sent out with the service truck to possibly get it fixed.
    You say problems "any monkey" could fix...unfortunately in a lot of cases, "any monkey" would be more capable than what's actually behind the wheel.
  11. Highway Hypnosis
    144
    135
    Apr 12, 2014
    Minot, ND
    Got a lot of use from the DeWalt 204 piece ratchet set. Very portable. Good for trucking.
    I'll also suggest one more tool:
    Large crescent wrench. A co-worker had an exploded brake chamber & was stranded along side the road. I re-routed his air hoses, backed off his brakes & had him back on the road in 30 minutes. Large crescent wrench was the ideal tool. Channel locks could also work but are more likely to cause damage.
    I saved this driver over 3 hours of down time.
    nax, Lepton1 and cnsper Thank this.
