Must we start at gear 1 or 2?
Discussion in 'Questions From New Drivers' started by AdnanNZ, Aug 25, 2007.
  1. AdnanNZ
    AdnanNZ Bobtail Member
    17
    I got a new Hino truck. It has 8 grears. I found it very comfortable to just use gears 5,6,7,8 and then driver it like a small pick up when its not loaded! It starts smoothy with gear 5 and it makes it very easy at intersections. A driver told me..its a big mistake, but he couldnt explain how is it a mistake?! Is it a problem to start moving the truck at high gear if it can produce enough torque to move? or do we must start with gear 1 then 2 then 3..then 4...etc
    Thanks in advance...!
  3. Brian22
    Brian22 Light Load Member
    95
    16
    Aug 21, 2007
    Dallas, Tx
    I would think it could wear out the internals of the transmission faster, a friend of mine used to do something like that in his chevy pickup, and he quickly learned why he shouldnt do it (after he replaced his clutch for the 4th time he stopped doing it)
  4. wallbanger
    wallbanger "Enemy of showers everywhere"
    It doesn't damage your transmission, but it does put a lot of extra stress on your clutch, leading to premature wear ( like brian said).
  5. Tip
    Tip Tipster
    2,294
    292
    Mar 18, 2006
    ON STRIKE
    Whatever gear you start in, it should be on the opposite side of the pattern from reverse. I've seen so many guys start out in what they thought was 2nd, only to be in reverse instead. It's very easy to get it wrong and back over somebody. It's too easy, in fact.
  6. MXH
    MXH Light Load Member
    101
    6
    Jan 28, 2006
    What is a Hino truck?
  7. wallbanger
    A japanese truck, usually a cabover straight truck (at least here in the U.S.)
  8. kd5drx
    kd5drx <strong>Master of Electronic Communications</stron
    485
    102
    Nov 28, 2006
    Some where USA
    any gear you start in should be one that the truck starts off smooth with no slippage of the clutch. This is the worst part of starting off in a higher gear is you put wear and tare on the clutch like folks said but you also put a strain on the rest of the drive line to with allot of torque to the u joints and drive shaft and rear end gears it will also cause some damage there if your not careful so i would suggest the 2 or 3 gear at least in the low side of trans rather that the high side.
  9. AdnanNZ
    17
    Thanks for the replies, It makes all sense....so...driving the engine at high RPM is bad to the engine and sudden torque (using high gears instead of low gears) on the transmission wears the cultch and transmission system.
  10. Attitude:)
    Attitude:) "Love each Day as if it was your last"
    510
    36
    Jul 13, 2007
    TX NM & CO
    If it lugs it down any doens't it damage the turbo too? Just curious.
  11. Sushitrucker
    Sushitrucker Bobtail Member
    8
    Hayward, CA
    I used to drive a Hino bobtail. Great little trucks!
    I heard the engines were too weak, so later they started using engines made (IIRC) by GM.
    In my opinion, you should always start out in first gear. It's murder on the clutch to attempt any shifting-shortcuts. An exception might be, if you are pointed downhill and will roll away from a stop; or if you're at some totally empty intersection, and made a slow-rolling "California stop" at a stop sign.
    But if a cop sees you do that, don't blame me! ;-)
