Mx13 belt replacement
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by uhjohnson, Apr 19, 2019.
  1. uhjohnson
    uhjohnson Bobtail Member
    43
    Jun 13, 2014
    I just had my serpentine and water pump belts changed on my 2015 Kenworth MX13 and the dealer charged me for the removal of the radiator fan. Did it have to be removed and if so can it be done without shifting the radiator
  3. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    I have never had to remove a fan blade to get belts on the MX in any chassis. The crank to fan drive belt is very short but I can ussually stretch it over the fan one blade at a time.
    If the fan blade did require removal the radiator would most likely need to be leaned forward to get to the nuts without turning the back of your hand into a bloody pulp.
    BoxCarKidd Thanks this.
  4. uhjohnson
    43
    Jun 13, 2014
    Does the KW shop manual say to remove the fan
  5. Mr Bob
    Mr Bob Light Load Member
    262
    81
    Mar 17, 2015
    Dont remember ever having to remove a fan to change a belt. I guess theres always a 1st time, and lost memories. To be honest I think you got raped. I feel your pain I paid almost 1k today to fill an argon bottle.
  6. Goodysnap
    3,716
    9,022
    Jul 12, 2017
    Older Cats with v-belts and Horton clutch is a good example. I'm sure there are others. The crank to fan hub belts were too short to go around the blade. Either pull the hub off the block or pull the blade was the only option. Seemed like every one that came in had new alternator belts and the fan belts were cracked and worn to ####.
    spsauerland Thanks this.
  7. Dickdogg1
    Dickdogg1 Bobtail Member
    9
    Aug 29, 2018
  8. Dickdogg1
    9
    Aug 29, 2018
    Nope the fan does not have to be removed and they probably didn’t remove it either.
