MX13 with 500K on the clock, suggested maintenance items?
Discussion in 'Ask An Owner Operator' started by scoobertdoo, Jan 6, 2021.
  1. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    Being more familiar with the ISX engines, I am not as up to snuff on the needs of a paccar MX 13. I know at 500K on the cummins you want to do a bottom end. So what should I do to make sure I dont have catastrophic failure on the road?
    BTW if some future person stumbles on this thread, the trick to get a MX13 home after a bad derate is apparently to unhook the speed sensor. I've not tried it, but was told this is what can save me.
  3. 062
    062 Road Train Member
    6,216
    33,467
    Oct 20, 2013
  4. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Rollers on the camshaft.
    scoobertdoo Thanks this.
  5. runningman0661
    5,213
    15,190
    Mar 5, 2009
    Clover, South Carolina
    How about reading the owners manual?
  6. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    Does the Cummins owners manual talk about liners slipping and blowing a head gasket? Cam shaft wearing out early? Egr valve failing constantly?
    This is the info I am after. So I can carry a spare part to keep the truck running if I have a breakdown. Had been planning to carry an egr in the Cummins...
    Ruthless Thanks this.
  7. Dave_in_AZ
    388,618
    Wait. I have 735K on my ISX.:biggrin_25524:
  8. pushbroom
    pushbroom Road Train Member
    1,779
    7,313
    Sep 1, 2012
    There is no speed sensor. Speed comes from the ABS ecm. Unplug the ABS fuses and it will bypass the speed derate but not the torque/rpm derate.
    No reason to do a bottom end at 500k on a cummins. Mains/rods are only changed at inframes unless the engine has seen severe abuse.
    Get a top set done, EGR flush and air managment sensors cleaned. Could replace the DEF filter too. Check it over for exhaust/fuel/coolant leaks. Inspect the idlers and belts.
  9. 77fib77
    77fib77 Road Train Member
    10,597
    66,572
    Jul 7, 2010
    St Louis
    Lol. It's an fing bomb. Unm you roll the bearings?? Cough, cough.
    magoo68 Thanks this.
  10. Dave_in_AZ
    388,618
    Negative ghost rider. Everyone has said it's a bomb since I had it. 400K miles ago. $400K give or take.
  11. 77fib77
    10,597
    66,572
    Jul 7, 2010
    St Louis
    5 by 5. Mine spun a bearing at 740k. Bad day. It idled weird fir about a week. I'm like " when I get back to Jersey, I'm going to take it to a mechanic" never got there.
    Dave_in_AZ Thanks this.
