My 07 century is lagging after I filled up fuel at Love's in Tom's brook VA yesterday
Discussion in 'Freightliner Forum' started by nsxftw, Sep 25, 2014.
  1. nsxftw
    nsxftw Light Load Member
    192
    39
    Dec 2, 2011
    n/a
    My cel is going off and on and it really laggs when I tried to go up hill. I thought turbo was acting up its fine on flat road but around 50mph to 65 .it's kinda lagging that boost won't work off and on.
    I changed the fuel filter where it was dirty so it didn't do anything.
    Anyone knows what could that be? Petro shop put the diagnostic but they didn't find any code.
  3. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    Get some extra fuel filters and CK. for water in bottom of filter,if not best to go to the shop that made the eng. they can get it fixed before T/stop or F/liner dealer.
  4. Boethel
    Boethel Light Load Member
    102
    55
    Oct 25, 2010
    LaGrange, Texas
    I have had this problem before, I had to change the fuel filter twice, I think, before the trash was cleaned out.
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    loves has a higher bio blend than other stops. this causes less power. heard of this before, I have to drop a gear on some grades if I have fuel from loves, where as I do not have that prob with other fuels.
  6. Boethel
    102
    55
    Oct 25, 2010
    LaGrange, Texas
    ...and another reason not to go to Love's
  7. nsxftw
    192
    39
    Dec 2, 2011
    n/a
    Looks like my fuel filter I changed yesterday looks good. It's still acted laggs when I go over 60mph.
    Some driver told me fuel injectors might go bad. Could that be possible?
  8. nsxftw
    192
    39
    Dec 2, 2011
    n/a
    I took it to shop this morning and they said i have code 39. They said its roughly 2-3hrs jobs through what's the problem such as turbo,injectors,egr valve, etc. Won't work till tomorrow afternoon or Wednesday morning. :(
  9. mhyn
    mhyn Road Train Member
    4,255
    4,514
    Dec 29, 2008
    Northridge, CA
    the code 39
    DESCRIPTION OF FLASH CODE 39
    Flash Code 39 is used for several EGR (Exhaust Gas Recirculation) system or VNT (Variable Nozzle Turbine) operational faults. These codes are typically logged in the ECU when one of the components are faulty.
    SAE J1587 EQUIVALENT CODE FOR FLASH CODE 39
    The SAE J1587 equivalent codes for Flash Code 39, EGR valve fault:
    s 146/2, EGR leak - Boost Power
    s 146/12, EGR leak - Boost Jake
    s 146/7, EGR Valve not responding
    The SAE J1587 equivalent codes for Flash Code 39, VNT vane fault:
    s 147/2, VNT Vanes not responding - Boost Power
    s 147/12, VNT Vanes not responding - Boost Jake
    s 147/14, EGR flow too low s 147/11, VNT Vanes at Max - Jake
    s 147/7, VNT Vanes not responding - EGR
    There are no wires to check for Flash Code 39. The sensor values and the ECU calibration are used to decide a mechanical fault is present.
    TROUBLESHOOT FLASH CODE 39
    The following procedure will troubleshoot Flash Code 39.
    For all EGR related codes, always perform the basic checks in EGR-1. Performing the basic checks will troubleshoot the components that will be responsible for logging these codes for Series 60 engines refer to MAINTENANCE ALERT SYSTEM.
    If the basic checks all pass, and no fault can be found with the VNT/turbocharger or EGR valve, then it is recommended that the information you have collected be available to discuss with Detroit Diesel Technical Service.
    1. Code s 146/7 - occurs if actual EGR rate during EGR mode operation is less than it should be. This fault will lock boost mode operation and illuminate the AWL for the remainder of the ignition cycle.
    2. Code s 146/2 - occurs if actual EGR rate during Power Boost mode operation is greater than a calibrated value. This fault will illuminate the AWL for the duration of the fault being active.
    3. Code s 146/12 - occurs if actual EGR rate during Boost Jake mode operation is greater than a calibrated value. This fault will illuminate the AWL for the duration of the fault being active.
    4. Code s 147/7 - occurs if error in actual EGR rate vs desired EGR rate (Actual - Desired) during EGR mode operation. This FMI signifies excessive EGR flow. This fault will lock boost mode operation and illuminate the AWL for the remainder of the ignition cycle if the actual is greater than the desired.
    5. Code s 147/2 - occurs if error in actual boost vs desired boost during Power Boost mode operation is greater than it should be. This fault will illuminate the AWL for the duration of the fault being active.
    6. Code s 147/12 - occurs if error in actual boost vs desired boost during Jake Boost mode operation is greater than it should be. This fault will illuminate the AWL for the duration of the fault being active.
    7. Code s 147/14 - occurs if error in actual EGR rate vs desired EGR rate (Desired - Actual) during EGR mode operation. This FMI signifies low EGR flow. This fault will illuminate the AWL for the duration of the fault being active.
    Verify Repairs
    Perform the following steps to verify repairs:
    1. Reassemble the engine.
    2. Start and run the engine.
    3. Perform a road test.
    4. Check for logged codes.
    [a] For Series 60 engines, refer to MAINTENANCE ALERT SYSTEM. Or, call Detroit Diesel Technical Service.
    If no codes are logged, repairs are complete.
    Copyright © Detroit Diesel Corporation 2004 - All information subject to change without notification
  10. nsxftw
    192
    39
    Dec 2, 2011
    n/a
    Thank you. They said it was delta p sensor went bad
  11. mhyn
    4,255
    4,514
    Dec 29, 2008
    Northridge, CA
    I think your engine is 06 model year. Check you engines model year . FYI some 07 engines were updated by Detroit Diesel and Delta P sensors were removed..google and you will find info about it..
