My AC does not blow in the front
Discussion in 'Questions From New Drivers' started by Southsidetrucker, Mar 15, 2025.
  1. Southsidetrucker
    Southsidetrucker Bobtail Member
    16
    15
    Jul 6, 2022
    Fellow truckers. My AC does not blow up front but blows just fine in the sleeper. There is no air coming out at all actually . I checked the AC compressor and it seems to be working just fine.
    Any idea what the issue could be ?
    2020 freightliner DD15
  3. El Hueso
    El Hueso Medium Load Member
    466
    1,315
    Dec 29, 2024
    El Paso. Tejas
    The blower motor isn't running. It could be the motor, the fuse or the resistor pack. It's very unlikely to be the blower motor, but could be. Have to investigate further. I have seen a lot of the Freightliners burn up the resister packs. Well, at least the ones that run a lot of A/C like FLA, AZ etc. Does yours run on any speed? Only on high? Check your fuses. The sleeper is totally separate. Pay no attention to that. I just did the blower motor in my 2023 Pete. Was easy. The Freightliners aren't bad if you are fairly mechanical. See what speeds are out. If no blower speeds work, go check the fuses. You could have the melted wire/connector issue.
    FullMetalJacket Thanks this.
  4. tscottme
    tscottme Road Train Member
    Does it sound like the fan is blowing, can you hear the difference in fan speed as you adjust the fan speed from low, medium, and high? If you hear the fan speed changing as you change the fan speed control, the mechanism that directs air to the defrost, vents, floor is probably getting stuck or stopped from directing airflow where expected.
  5. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,505
    2,594
    Jan 7, 2023
    Did the motor make weird screeching noises before it stopped blowing air, or did it just stop working one day?
    tscottme Thanks this.
  6. Southsidetrucker
    16
    15
    Jul 6, 2022
    It stopped blowing cold air for a day and now it doesn’t blow at all . I replaced the Blower fuse earlier today and still nothing
  7. Southsidetrucker
    16
    15
    Jul 6, 2022
    I r
    I replaced the fuses, but no luck. It is not blowing any air at all. It doesn’t matter if it’s on low or high I don’t have any air coming out
  8. tscottme
    CAN YOU HEAR MOTOR SOUNDS?
    DO THOSE SOUNDS CHANGE AS YOU INCREASE AND DECREASE FAN SETTING?
    JB7 Thanks this.
  9. JB7
    JB7 Heavy Load Member
    952
    1,642
    Dec 13, 2022
    Laurel, MD
    A - You can hear the fan motor but air is not coming out of the vents
    B - You cannot hear the fan motor and air is not coming out of the vents
    If A then:
    1 - a duct hose may have come off
    2 - A critter plugged up some of your ducts
    3 - blend door or actuator is stuck
    4 - check your cabin filter
    If B:
    You will need to remove a panel(s) under the right/passenger side dash to get to the fan motor. You can then unplug the fan motor and test for 12v at the plug. You can also connect the fan directly to a battery to see if it works.
  10. El Hueso
    466
    1,315
    Dec 29, 2024
    El Paso. Tejas
    You probably have a melted wire/connector or it's the blower motor. I would suspect a wire, especially the blue one behind the passenger dash access. If, like the others said that you can hear NO SOUND that is. The contacts loosen up over time and they have to pass almost 30 amps through them. When they loosen a tiny bit they start to arc and burn up. This happens a lot. If you can't hear anything and your fuses are good (I think it may have been F10 but cant remember for sure) look into your blue and gray wire that runs to the fan.
  11. Ridgeline
    22,618
    120,267
    Omg, OP just bring it to a shop, it is way beyond your ability to fix it.
    El Hueso and JB7 Thank this.
