My alternator possibly the whole motor has shifted(moved).
Discussion in 'Ask An Owner Operator' started by just g p, Oct 13, 2019.
  1. just g p
    just g p Light Load Member
    94
    23
    May 20, 2013
    San Antonio, Tx
    Does anyone know what could possibly cause my Alternator to move and start touching this bar.
  3. AModelCat
    159,375
    Could be anything really. Loose/broken alternator mounts, broken engine mounts etc. Could even be broken rad mounts making the rad shift. Gotta start inspecting stuff, shouldn't be too hard to find the source.
  4. baha
    baha Road Train Member
    4,137
    2,836
    Jul 25, 2013
    ga
    CK the ft. motor mounts for louse bolt or broken rubber mounts ?
  5. just g p
    94
    23
    May 20, 2013
    San Antonio, Tx
    Thanks. I'm doing a 34 reset today and I noticed it. I didn't really notice anything on top that was loose or missing,so I'm going to crawl up under the truck and see what I can find.
  6. just g p
    94
    23
    May 20, 2013
    San Antonio, Tx
    Will do,Thanks.
  7. spsauerland
    spsauerland Road Train Member
    4,296
    10,887
    May 31, 2010
    West Harrison, In
    Is the rad support rod bent in?
  8. just g p
    94
    23
    May 20, 2013
    San Antonio, Tx
  9. baha
    4,137
    2,836
    Jul 25, 2013
    ga
    Not sure but look under FT. of motor at lower side of crank pulleys for 2 large bolts going thru 4 big rubber bushings to see if bolts are broken but with hood open try to start off real easy in gear and watch if alt. hits rad. support bar?
    Dave_in_AZ, Farmerbob1 and just g p Thank this.
  10. FoolsErrand
    FoolsErrand Road Train Member
    2,877
    12,169
    Sep 15, 2017
    I dont think the alternator fins hit that bar. Check for bolts backed out or missing front the timing cover.
    Getting crossed up on rough ground will twist a frame all up. Put your front wheel on a curb and the hood may not even open, for instance.
  11. Bean Jr.
    Bean Jr. Road Train Member
    5,505
    9,789
    Mar 30, 2014
    Broken ears on the alternator.
