My coolant Resevoir issue on my X-15 Cummins
Discussion in 'Ask An Owner Operator' started by Coma1, Apr 8, 2023.
  1. Coma1
    Coma1 Bobtail Member
    16
    19
    Oct 31, 2019
    My coolant reservoir on my X-15 Cummins ,any time I start the truck after 10-15mins it’s says low on coolant amber light comes on .I changed the sensor coolant is always full but still keep saying low on coolant.Any thoughts .check the wiring and everything is good condition .
    D.Tibbitt Thanks this.
  3. D.Tibbitt
    151,006
    Been a common problem for awhile.. You got to replace the whole coolant tank because the sensor communicates with a magnet(?) Or some device inside the tank that gets stuck and the sensor reads low... I had my sensor unplugged for the last 2 years agter throwing 3 tanks at it and probably 6 or more sensors.. It will illuminate a check engine light when unplugged but will get rid of that constant god awful low coolant alarm... The aftermarket coolant tanks are like $400 if ya wanna keep changing it out... Ive never got more then like 6 months out of a tank before the sensor fails on it
    High Stepper, Last Call and Siinman Thank this.
  4. Spyro2112
    Spyro2112 Medium Load Member
    604
    416
    Mar 17, 2018
    Run the electric line there is a module change it, as long as it doesn't shut down the truck no big deal
