My Detroit s60 12.7 is very loud first 50-100 miles? After that not so much?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by CellNet, Jun 28, 2020.
  1. CellNet
    CellNet Light Load Member
    206
    82
    Jun 19, 2011
    Chicago IL
    What causes engine to be loud like that:
    after an hour/two of driving is not that loud anymore:
    what do you think about it?
    no exaust leak, valve adjustment is done.
  3. CellNet
    206
    82
    Jun 19, 2011
    Chicago IL
    Turbo boost is 32-35. No boost leaks.
  4. bad-luck
    bad-luck Road Train Member
    3,357
    6,206
    Nov 16, 2013
    Baltimore, Maryland
    Is there any loss of power? Or does engine run normally other than being loud?
  5. CellNet
    206
    82
    Jun 19, 2011
    Chicago IL
    Exhaust valves? Wrong timing? I am running out of ideas!
  6. bad-luck
    3,357
    6,206
    Nov 16, 2013
    Baltimore, Maryland
    Is the engine running normally other than the loud engine?
    CellNet Thanks this.
  7. CellNet
    206
    82
    Jun 19, 2011
    Chicago IL
    Yes, I think so. Even boost is good on higher gears is kind of lazy. On lower gears seems fine.
  8. CellNet
    206
    82
    Jun 19, 2011
    Chicago IL
    Yes, it does.
  9. bad-luck
    3,357
    6,206
    Nov 16, 2013
    Baltimore, Maryland
    When you're 1st describing it being loud it makes me want to think before it warms up, however you're stating 50 to 100 miles which is an hour to an hour and a 1/2. I would say start with your exhaust manifold, make sure there are no leaks around the manifold. I know you said there were no exhaust leaks but double check everything.
    BoxCarKidd and CellNet Thank this.
  10. CellNet
    206
    82
    Jun 19, 2011
    Chicago IL
    Good point. I will do that.
    bad-luck Thanks this.
  11. Rideandrepair
    17,424
    56,529
    Aug 8, 2015
    That sounds like a big difference. Mine always sounds louder when first started. Spark knock especially, like the pistons are slapping, till it warms up. Look for black soot, on the whole exhaust. It could be the muffler(s)
