My first job in a van Trailer as a P&D Driver, Will track my first Year!
Discussion in 'LTL and Local Delivery Trucking Forum' started by Josherd87, Feb 21, 2014.
  1. NastyWardog
    NastyWardog Bobtail Member
    14
    19
    Jan 25, 2014
    Youngstown, Ohio
    Hope you like P&D, it takes a little time to get use to. Sometimes you feel more like a secretary that also drives a truck. Don't count on the GPS always double check the routing it gives you. Keeps you out of a bad situation. I run P&D in Pittsburgh and have been in a few spots I wish i wouldn't have been in, but its part of the learning. Best advice I can give is stay safe, take your time and call your p/u or delivery if your not familiar with where you are going. It doesn't pay to rush through your day and take chances. If something happens you will be hung out to dry. In time you will learn your customers and get more proficient at the job. Job will be overwhelming if you let it. Be safe and good luck..
  3. Josherd87
    Josherd87 Light Load Member
    84
    17
    Feb 19, 2014
    Columbus, Ohio
    Nastywardog: Thanks, definitely going to be different but I'm looking forward to driving during the day. I had always drove third shift. The sun might melt me at this point lol
  4. NastyWardog
    14
    19
    Jan 25, 2014
    Youngstown, Ohio
    With the daylight driving comes the traffic x3. If you remember that its your CDL, and keep that in mind you will do fine. You will do things in P&D that goes against everything you learned on the road pulling a skateboard. There is no substitute for common sense. Always check everything out, like if there is a dock, can i get turned around once i pull in, things like that. Lots of places you have to back in off the road, or get loaded on the road. Lots of differences you will learn. But take it slow and learn your customers. Its prob going to take you a few months to settle in, but you can do it. It's a descent job and one of the better paying driving jobs. Home every night is a plus. Keep us posted on how things go for you.
    RookieJ1987 Thanks this.
  5. Moving Forward
    Moving Forward Heavy Load Member
    737
    727
    Jan 14, 2014
    New England, USA
    Lots of great advice from NastyWardog! The above line about not rushing is an especially important aspect of driving, IMHO. Good luck with that GPS (I have the same one), but don't forget to have AND USE a good old fashioned paper atlas with you as well. In some areas like downtown NYC, the GPS reception is not very good and can cause an unpleasant surprise if you're always counting on that for guidance.
    Enjoy your new journey!
    NastyWardog and vavega Thank this.
  6. Brandonpdx
    Brandonpdx Road Train Member
    4,249
    4,073
    Dec 27, 2007
    Elkhart, IN
    Well you need your NYC truck route map if you're going in there, and try to stick to the red "thru routes" if you can. (The blue "local" routes don't always have 13'6" clearance.)
  7. vavega
    vavega Light Load Member
    295
    177
    Oct 13, 2009
    maple shade, nj
    some words of advice josh....
    get yourself a good handtruck, not the fancy one that turns into a cart but a decent one and strap it to the catwalk. doing ltl you might end up with either tailgating in the street or inside deliveries. if you do get them try to identify them as soon as you can so when you do hit a dock before one of them you can pull that skid or 2 to the tail making it easier on yourself. sometimes if the skid is light you can use the plate of the handtruck to slide the pallet to the end or unload half of it and then slide it.
    if would always ask to see my run the night before so i could write down the address of any new delivers. then when i got home i would use streetview to see the building looking for docks, how tight it would be etc. saved my sorry *** more than once.
    always have at least 3 spare 4 ways if you run a 102" to block in the pallet you pull back. always put it on the right side and leave it about 6" from the door. that way when you climb up you have somewhere to put your feet.
    Moving Forward Thanks this.
  8. Josherd87
    84
    17
    Feb 19, 2014
    Columbus, Ohio
    Nastywardog: Thanks for all the great advice. So many people on here have helped so much. Trust me, I wont be rushing around lol they go at my pace or they go around. I don't believe in risking lives or equipment for rushed drivers. Hopefuly they work me into the harder spots slowly but I doubt it so ill just do my best. Luckily I am only running within a 250 mile radius of Columbus ohio, so no NYC or areas like that. Only PA, Indiana, a little WV and Kentucky They also said most of my routes will get familer because its the same customers. So ill get to know the places I go. HOPEFULLY
    Vavega: Our trucks are going to have pallet jacks in them I do believe, incase some hand loading/unload or I need to move pallets around. And we get our runs computer generated in the mornings from the computer so I wont be able to get them the night before, but I wish I could have you explaining that to me. Ill just have to google maps places with my phone. I would hate to get to a place and have to circle it or worse to try and get in. Although im sure it will happen.
    I fully expect there to be learning curves and tough times. But we all start somewhere, im just happy to get away from pulling a skateboard...Those tarps in the winter SUCK haha
  9. Big Don
    Big Don "Old Fart"
    17,996
    35,643
    Sep 8, 2007
    Utah's DIXIE!
    If you used a laptop w/air card on the road, and you still have the service, take it with you. You can use it for Google Earth to look at new stops. You may be able to do it on your phone, but the lap top screen, being bigger, is a better look.
    Your company isn't expecting you to start off as a veteran LTL P & D driver. No matter how much experience you have, when you go from a road job to a local job, (or the other way, for that matter,) they know you will have a lot to learn.
    The two biggest things are SAFETY, and customer service. And you will have folks who put the "CUSS" into CUSSTOMER. . .
    vavega Thanks this.
  10. vavega
    295
    177
    Oct 13, 2009
    maple shade, nj
    having that pallet jack is great. 3 of my buddies and i went in on one together because occasionally we had to do house deliveries that were more than 4 skids and heavy. the worst was some places that had no dock, a forklift but no pallet jack. it was like really? you couldn't spare a couple hundred for a pallet jack? :)
    as big don says if you can, carry that laptop and air card. if the aircard and wireless service is too much right now then carry the laptop and get microsoft streets and trips for all the maps you need.
    i'm a little confused as to what you mean by
    ask anything your concerned about and all of us will help you. you seem to be sincere and really want to do a good job. it's easy to help someone with that kind of attitude. a little more yes i can do this and less focus on the omg what have i gotten myself into and you'll be fine. :wink:
  11. Josherd87
    84
    17
    Feb 19, 2014
    Columbus, Ohio
    Vavega: I guess I did say that weird. What I meant was, After you explaining how you got your routes before and looked it up on Maps, I wish I could get mine the night before. That seems like it would be very helpful.
    And your right, I do want to do a good job, Safely! I have to be at work no matter what so why not spend those hours trying my best and actually EARN my money instead of just trying to float through the day.
    BIGDON: I think you have customers like that in just about EVERY industry lol Just think guys we could always work the complaint counter at Wal-Mart haha
    Big Don Thanks this.
