My first maintenance issue
Discussion in 'Questions From New Drivers' started by bigdaddykd, Jul 29, 2011.
  1. bigdaddykd
    bigdaddykd Bobtail Member
    Houston, Texas
    I didn't see a maintenance section, therefore I decided to post it here. After refueling both tanks I noticed that I was running out of gas quicker than normal. I stopped again to refuel and noticed that my driver's side tank was filled to the top while the other tank was completely empty.
    Can anyone tell me why the truck stopped pulling gas from one tank? I am also getting poor gas mileage. My buddy has the exact same truck and he's getting four more miles to the gallon than I am. I am getting right at 8 miles per gal (highway). I've changed the gas filter, and check tire pressure weekly. I have a 2000 Freightliner with a Mercedes egine and its a 6 speed.
    Thank you for any info you can provide
  3. trucker_101
    trucker_101 Heavy Load Member
    941
    639
    Apr 23, 2010
    Alberta
    First, do you mean gas? or diesel? Two things I can think of but there could be more, are
    1; cross over line valve between the tanks is closed.
    2; vents in the tank that's full are plugged.
    But it would probably help if you gave us more info on the type of truck?
  4. paul 1052
    paul 1052 Heavy Load Member
    899
    346
    Oct 9, 2010
    Sand Springs, Ok.
    Beat me to it... gas?
  5. FLATBED
    FLATBED Road Train Member
    My buddy has the exact same truck and he's getting four more miles to the gallon than I am. I am getting right at 8 miles per gal (highway). :biggrin_25513: Like to see your BUDDIES truck that gets 12 MPG also like to see a 2000 FRLR Highway tractor with MB engine in it , think they were introduced in 2003 in the CLASS 8 trucks.
  6. Allow Me.
    10,727
    12,426
    May 28, 2009
    Rancho Mirage, Ca.
    Like Joe Friday used to say...."Just the facts, Mam"
  7. BigJohn54
    BigJohn54 Gone, but NEVER forgotten
    1,972
    1,599
    May 13, 2011
    SW Missouri
    What kind of truck? What are the truck specs? Diesel or gas? What kind of trailer? How heavy is the equipment? How heavy are the loads? What part of the country do you run in? Do you check the mileage using gallons burned divided by miles traveled or do you depend on what some gadget tells you?
  8. American-Trucker
    American-Trucker Road Train Member
    10,371
    5,085
    Nov 8, 2009
    Charlotte, North Carolina
    ITS NOT A TRACTOR!!!! HELLO!!!!!
    Come on guys READ his post, 2000 FL with Mercadies, 6 SPEED, GAS.
    It's a straight truck!
    American Trucker
  9. FLATBED
    HELLO
    Freightliner had the 5ton VERSIONS ( straight truck ) with MB diesels in them in 2000 as well.
  10. BigJohn54
    1,972
    1,599
    May 13, 2011
    SW Missouri
    I agree but a little more information could validate this and lead to some insight for the OP.
  11. CarlLegend
    CarlLegend Light Load Member
    144
    42
    Jul 16, 2011
    Something can have been sucked up into your pick up pipe (suction pipe or what ever its called there) therefore it is drawing very little from that tank. Or as said, that tanks breather could be blocked.
    Blow the pipes to make sure they are clear.
