my new ride. deal or bad deal. 2000 Columbia with the N-14 500hp
Discussion in 'Ask An Owner Operator' started by gerryger4444, Oct 7, 2014.
  1. gerryger4444
    gerryger4444 Bobtail Member
    6
    Hi I just bought my first old used truck. I have had one brand new and one 3 years old(both turned out to nightmares after a year in each,, egr/emission nonsense) but thi
  3. allisonisatranny
    allisonisatranny Light Load Member
    188
    131
    Oct 6, 2014
    Well, if you have to finance it, what do you do if you break down and can't afford road service? You never said if you had money saved up...
    gerryger4444 Thanks this.
  4. Cetane+
    Cetane+ Road Train Member
    1,304
    882
    Sep 29, 2013
    Albany, NY
    That N-14 will work far longer than you can or will. Really one of the best blocks for highway trucks ever built (855 block). The only complaint I have about them is the rocker box seals. Good luck! Work your ### off, and make it work for you.
    mrbamcclain, Puppage and gerryger4444 Thank this.
  5. Victor_V
    Victor_V Road Train Member
    2,797
    1,494
    Dec 15, 2008
    Spencer, Indiana
    Sounds like a great starter truck ($13K) to me on great terms ($1K down, $1K/month, no interest).
    My bet the seller will work with you in a bind, too.
    gerryger4444 and paul_4lp Thank this.
  6. 201
    201 Road Train Member
    12,372
    25,288
    Apr 16, 2014
    high plains colorado
    Hi gerry, well, depends what you are going to do with it. I think you did ok, as you got thousands of dollars in tires on the deal. I would have done the samples 1st, but sometimes, that's not an option, and I'm sure people have spent 5 or 6 times that amount, got good samples, and still had trouble. With 1.3 on it, it for sure had a major (or 2) so I think you did ok.
  7. Derailed
    Derailed Road Train Member
    2,383
    2,657
    Dec 10, 2008
    Upstate NY
    Sounds similar to my first truck which was a Marmon I purchased back in 96. Guy didnt know me from Adam and let me drive off with $3000 down. Paid her off in a year and ran the nuts off it. Never let me down. Sounds like you did good. Ive always heard good about the N14s. Good luck.
  8. DonM
    DonM Light Load Member
    148
    78
    Jun 22, 2012
    Southeastern USA
    If you are getting 6.7 mpg the motor must be in pretty good shape. I would take it by a good Cummins mechanic and get the blow by checked and have the overhead checked. Sounds like you ran across a sweet deal. Do you have any service records to reflect upon?
  9. rollin coal
    rollin coal Road Train Member
    13,302
    26,900
    Mar 29, 2008
    TN
    I wouldn't waste money on rods and mains. Keep it for later when it'll need an inframe.
  10. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Great purchase in terms of the financing. Miles are actually pretty low for the year, considering there are 08's out there with a million and a half miles on them.
    A at 14 years old, corrosion is going to be a major concern. If you ever manage to get a bolt out/nut off, replace it with grade 8 stainless steel with anti-sieze on the threads. Make sure all the unused holes in the frame have a snug fitting bolt in them with a lock washer, washers on both sides, and a castle nut and cotter pin where possible (keeps the frame from cracking around the holes). Wiring is likely to be your most major issue behind suspension. A good alignment shop will be able to spot badly worn suspension components before they cost you those new tires in short order. Any wire loom exposed to road spray should be opened, cleaned (connectors AND insulation) heat shrunk where possible after any worn wires have been repaired or replaced, dielectric grease applied to all cleaned connectors, and wrapped in new, high quality loom sheath, and securely fashioned to the frame or body with padded loom clamps abs la wide, high quality zip ties (they make nuts that fit on frame bolts with slots for clamps and zip ties, and you'll have plenty of thread left after filling those empty frame holes).
    Insofar as the engine, they're pretty well built. The blocks had been in production since the 1970's, so they got the kinks worked out on those. Stay on top of keeping the coolant pH balanced, and consider having the coolant system citrus flushed. All of the rubber is likely at the end of its life, so you'll need new hoses on everything. CAT will build any hose you need with re-useable heads, which will save you money when you get a hose replaced a second time. Do the fuel hoses first, then the brake air lines, then the rest of the air lines all the way up to the tanks, and from there up to the compressor (don't forget the check valves).
    None of this has to be done right away. 2-4 hours a week will get it all done in about 2 months. Should help you cruise smoothly into that rebuild.
    Victor_V Thanks this.
  11. gerryger4444
    6
    I didn't need to finance it but I was offered it so I took. I have plenty of money to cover anything I need for breakdowns and such.
